Saylor Beall Compressor
djd99
Owosso,Michigan
I bet its the key you should be able to get that at any hardware store
Yup pull the Flywheel off your key is junk go to tsc and buy some square stock and make your own key if they don't have any the length you need, If I remember right the key is extra long witch might make it hard to find at least mine was.
Also you'll have to pull the rod caps off and inspect the bearings there was a reason the key snapped. If you pull the rod bearings and there still smooth and no grooves you'll likely be able to reuse them, I would replace them no matter what if I was you.
Especially if you want your nice rebuilt pump to go another 20 years. I put new rings, rod bearings, new site glass,gaskets and head kit on mine. Still need to get in the garage to finish it been working on a shelf for the old lady for her Birthday. Maples a blast to work with.
E
edl
Southeast, US
i think the key broke b/c the belts were loose - and one looser than the other (ie, motor angled a bit) - but i could be wrong
having never done this, can you describe exaclty where the key goes - is it something that slides all the way down the spindle to crankshaft?
djd99
Owosso,Michigan
taking the flywheel off seems straight forward
but how do i take the crank out?
First take off the rod caps I marked mine first so I knew exactly witch rod they were mated too and what side. once the rod caps are out the pistons and rods come out the top. Also you can remove the jug bolts and remove the jug and pistons out the same time if you choose. But both pistons have to be removed to inspect the piston side skirts,rings and condition of cylinder bore.
djd99
Owosso,Michigan
Now start disassembling the unloader assembly. Once you have that all apart the crank comes out the front flywheel side, remove the bolts on the front cover and take a dead blow hammer to remove the crank.
E
edl
Southeast, US
so a couple of more data points
when i turn the flywheel, the shaft it is on turns
on the inside, the round area where that shaft enters connects to something, surrounded by bearings - when the shaft attached to the flywheel turns, that bearing set turns too
but, the crankshaft does not turn
when i turn the crank by hand, the same set of bearings on the opposite end, the end that connects to the centrifugal unloader turns - the end connected to the flywheel does not
so - is the key the piece that conncets the crankshaft to the flywheel shaft?
do you guys still think that the key is the issue here?
thanks!
djd99
Owosso,Michigan
thanks!
Yes the key is between the flywheel and crankshaft in the machined groove, if the key is sheared the flywheel will turn and the crankshaft will not. If your flywheel is turning so should the rods and pistons if your key is good.
replace your key and report back.
fordor
Saranac, MI.
I have a SB compressor and can atest to the quality and reliability of these units. Mine is a 80 gal 5hp. unit. I have had it 15yrs now and it has served me well. I got it straight from the factory as I live close to St. Johns, MI. where they are made. I was able to pick it up at the factory. It took three guys to get it in place. They are very well built units. I would recommend them to anyone serious about having a reliable compressor:thumbup:.
Bob L.
kams1973
Amarillo, TX
When you turn the flywheel, the shaft turns as well, but it does not turn the crankshaft inside the pump. Sounds like the crankshaft has failed. Remove the flywheel and the front plate the crankshaft goes through on the pump. Once you do this you should get a better idea of what is wrong.
E
edl
Southeast, US
OK
Once I have the flywheel off, do i have access to change the key?
if not, how do i get at it? - does it involve having to take the entire crank out? - i know the recommondation is to fully rebuild the crank, check bearings, take of the rod cap and check those bearings - and i might
i know the upper end is good - i took the head apart and took the jug off (with the pistons still connected to the crank) - and so was able to tell the jugs look like mirrors, rings are sharp and look good
but, if i want only to deal with the key at the moment, what is the direct rout to that fix?
thanks all
:beer:
djd99
Owosso,Michigan
OK
thanks all
:beer:
Pull the flywheel off the crank with a jaw puller, there will be a groove in both the flywheel and in the crankshaft. There should be a key 1 1/2" long most likely this key is sheared and the reason your crankshaft is not turning. It would really have to be a bad casting to break a crankshaft. I've never seen it happen yet.
E
edl
Southeast, US
djd - confused - the shaft the flywheel is on right now, is that considered part of the "crankshaft"? - not having taken it apart yet, i am envisioning that there is a connection between the flywheel shaft (for lack of a better word) and the crankshaft and this is where the key goes
or is it that it is all one piece and that only thing we are talking about is a slot in the flywheel and a slot in that outer part of the crankshaft and the 2 connect with the key? - i am thinking this second option can't be b/c when i turn the flywheel, the shaft it is on turns - and the bearing cup turns - but what i call the crankshaft (inboard of the bearing cup) - this part does not turn
kams1973
Amarillo, TX
The crankshaft is all one piece. The flywheel connects to the crankshaft and the connecting rod connect to the crankshaft journals inside the pump.
djd99
Owosso,Michigan
Here's a question edl You say when you spin the flywheel the crankshaft turns witch is the shaft the flywheel is connected to, does the rod journals move inside(The rod journals are what the rods are connected to)? If the rod journals don't move when you spin the crankshaft, The crankshaft would be broke "witch is very rare" Make this clear for us.
E
edl
Southeast, US
djd - exactly right - when i spin the flywheel, the part of the crank that the flywheel is attached to spins with it (so i think that means the key is ok) - BUT, the rod journals do not turn
dang! - i guess that means the crankshaft is broken - because it is a solid piece, right? - so if any part of the crank spins (like at the flywheel) and any part doesn't (like the whole rest of the crank just downstream of the first bearing cup), the crank is broke, right?
kams1973
Amarillo, TX
Don't give up and don't trash the pump. Find a crank somewhere. They are quite expensive new I'm sure, but you may be able to come up with a used on somewhere.
E
edl
Southeast, US
Kams - where?? - a Saylor Beal crank part number 4050 - where does one even start looking for that? - that is the first generation crank - of three
if it is a clean break, is is something a professional welder can fix??
kams1973
Amarillo, TX
I have a friend that has 3 sitting in a junk pile in his yard. I'm out of town right now, but when I get back I'll check and see if any of them are the "old" style pumps. We might be able to salvage a crankshaft out of one of them for you. I'll let you know as soon as I find out.
djd99
Owosso,Michigan
Well if your crank is bad you need to tear down the complete unit anyway. Take the flywheel off first. Take out the long bolt in front of the flywheel. Then take a jaw puller and remove the flywheel. Now I want you to take off the front cover witch I believe has 6 or 7 bolts. If your crankshaft is broke this is where it sounds like the break will be. Take a picture I would love to see this as I never thought it would be possible to break such a heavy beast. Those cranks are massive.......... Don
E
edl
Southeast, US
very kind of you - thanks :thumbup:
E
edl
Southeast, US
maybe this is a guiness record - i'll enter the photo (with a copy to you!) and the money i win will pay for the new one :bounce:
E
edl
Southeast, US
by the way kams, what kind of friend has 3 of these at his house?? - does he work for SB?
930dreamer
Amarillo,TX and Stinnett,TX
Here are a couple of pictures of my dissemble showing the flywheel, keyway and crankshaft.
djd99
Owosso,Michigan
See The diameter of the crankshaft am I the only one that thinks this would be impossible to shear? I would think the rods would break before the crank!
E
edl
Southeast, US
djd - great pictures - thanks - i will break down the entire pump and we will have the answer - do not know how quickly i can do that, but i'll let you know
on a separate note, those stainless tabs that hang down from the rod caps... what are those for?
930dreamer
I'm betting the con rod bearing are shot, tabs pick up oil.
kams1973
Amarillo, TX
edl.....if the crankshaft is sheared and you don't have any pullers, etc, you should be able to just remove the six bolts on the front cover and pull it all out. Like djd99 said, we want PICS. BTW, the tabs are oil slingers.
E
edl
Southeast, US
well ... it is indeed the crankshaft - pictures say it all
kams, let me know if you have a used one?
E
edl
Southeast, US
crankshaft it is
it almost looks like it had been broken before and someone jb welded it
anyway, here you go
