very depressing snap on fail
jfcasey
New Hampshire
Saw something similar to this VERY recently with a brand new soft handled screw driver. Tip snapped exactly the same on the first screw.
wafrederick
Holton,Mi
Hand one to my neighbor Ken,you get the #2 phillips screwdrivers with the tip snapped off.Does this to every good including cheap brands and my father watched him break 5 of them on body molding screws one night.
DavidB
Navarre, FL
If the screw isn't rotating, torque on the handle is equal to torque at the tip regardless of the length of the shaft and amount of twist. If it's not then the screw or handle is rotating.
srmofo
SW ohio
Some of you are not getting it. Torque is a measurement of force. That isnt changing, its the wrong word in this case. Torsion is what people are talking about. The longer the shaft, the more torsion it will see.
DavidB
Navarre, FL
Yes, I understand that. Early in the thread someone said that a longer shaft generates more torque and I was replying to that.
Red Green
South Central Michigan
will they hand me a new screwdriver or do they pound another shaft in? i don't recall seeing any long shafts in my snappy dealers drawer (thats what she said) :lol:
As a couple of the other guys said the dealer can change the shaft. They might have to order one depending on how well stocked your dealer is. :thumbup:
I had a body molding screw snap the tip of a ratcheting screwdriver bit just like that the other day.
Danglerb
SoCal
Torsion in a screw driver is no more beneficial than bending is with a pry bar. I don't see what point your trying to make.
A complaint I've heard more than once about Snapon is that they harden their steel too much, so it wears longer, but isn't as tough.
Phillps #2 doesn't have to be too stuck before I would be looking for my impact driver.
kelwar
I had a tmp21e phillips socket that snapped the tip off like that :( but hey thats what warrantys for
RLRRLRLL
Spearville Kansas
all tools can and will break under use, no matter if its a snap on, mac, matco, craftsman, sk, harbor freight, walmart, dollar store, etc. Sometimes there are just flaws, does it mean the company *****? Nah, does it mean its made in china? Nope. Its like drumsticks..i buy oak ones as they generally last longer. I have broken 1 within 5 minutes of playing, but then i have a pair that ive used for a couple shows and they are still good. Sh!t happens.
DrkMtnDew
all tools can and will break under use, no matter if its a snap on, mac, matco, craftsman, sk, harbor freight, walmart, dollar store, etc. Sometimes there are just flaws, does it mean the company *****? Nah, does it mean its made in china? Nope. Sh!t happens.
that is about how it goes. the very cars and truck our tools work on are like this. the good and the bad. :)
reznunt
Socal
my harbor freight power bit did that same thing. the tip broke off trying to remove a drywall screw. my snap-on cordless screwdriver torqued it off.
William Payne
Wanganui, New Zealand
I have never seen a screwdriver or screw drive bit break like that but have seen then round off but it was a different brand that I can't remember but from my memory it only ever happened if the driver was not properly in the screw.
RAYJAY
UNION DALE PA
Have you contacted Snap On? Dealer?
i travel on the road, don't buy from one dealer, going to contact snap-on to get the replacement I need, but for the $$$$ i paid there tools are not worth it no support at all, i get better support from the harbor freight tool stores.....:wtf: than the snap-on dealers :shocking:
lipadj46
Last tool I had warranted by snap on it was a 5 minute phone call and I had the new tool in under a week and I did not have to send the old tool back to them.
lipadj46
As you twist on a long thin screwdriver you can keep turning and the shaft as twist it develops more energy. If the shaft didn't have a small amount of twist it won't make any differance. I didn't beleive it either until it was proved to me several times over.
That's not torque though. I agree that the shaft twists and stores energy and puts an additional torsional force on the tip. I believe that some tanks and heavy equipment use solid metal bars for "torsional" springs in their suspension.
plinker
Northern Wi
I removed a broken blade from an SDDP42 I have and sent it in to Snap-on for warranty (I had the part # for the blade itself) and got the new one back and installed it.
So you can get them replaced by mailing them in.
RAYJAY
UNION DALE PA
you pay top dollar for snap-on products...... as most people on here do it for the truck support, to me if i have a warranty problem any truck dealer should take care of me no questions asked, if i want to mail my tools in why pay the premium,:headscrat just buy gear wrench products, i can get them replaced in the mail that way and they cost a lot less,
Sterff
PA
I just broke my new 16" Craftsman Pro #2 yesterday as well. It was on the first screw and it broke just like the one pictured.
Hiball
Missery
Ok... I went back and Read this entire thread from top to bottom, Did you ever take it to a Dealer? Did you ever contact Snap on and give them the opportunity Make it Right? This Place has me so Confused.... If you want to buy Gearwrench/HF then do it, But i cant see how you can blame a Manufacturer for "Lack of Warranty support" if you dont contact hem regardless if the tool was $500 dollars or .50 cents. This place IS Amazing... LOL...
RAYJAY
UNION DALE PA
talked to a lot of the so called dealers, a example of my problem with snap-on is this...
when you buy off of a truck dealer in PA and you need th replace tool in NY no body want to do it for you and mail order i have to ship everything out and have it shipped back to my house, then have the wife reship it out to me in the field, the only dealers i have had problem with all the time is snap-on ..... mac and matco dealer are for the most part help full and will do what ever they can do to help
the manufacturer should make the dealers take care of "Lack of Warranty support" because it make snap -on look bad i didn't mail order the high price tool i bought it off a truck dealer i should be able to walk on any snap -on truck and get warranty not the excuse i hear all the time...."well you did you buy it from me?' or "if you buy something i can take care of it for you."
Jeff
jkeyser14
(rural) Maryland
The length of the shaft means nothing as far as torque goes, for a screwdriver a thicker handle would give greater torque
100% correct. Length has nothing to do with torque. However, the longer the screw driver the more deflection (twist) it will show. However, it's no more twisting per unit length than a shorter screwdriver, the added length just makes it more visible/perceptible since the cumulative degree of twist is now higher.
chadster1
Terrell, Texas
Jeff
Did you contact Snap-on with the names of the dealers who have denied you warranty service? There is no way Snap-on can address the issue unless they know about a specific problem.
Hiball
Missery
Jeff
Jeff... I dont doubt that there are some dealers who frown on "New" People stepping onto there truck with Broken tools looking for a Warranty. Is it Right? No but Happens i suspect. I have a Hard time believing that with all your Travels you run across this with Every Snap On dealer. I would have "NO" Problem calling Snap on and letting them know your Experience with the Dealer. I can gurantee you 1 of 2 things would happen, You would either have BRAND New screwdrivers on your Front porch within 5 business days or you would have a Postage paid Slip to ship your Tools back to Snap on for Full Replacement. If your tired of trying to Warranty your Snappy stuff, Let me know what you got and i might be willing to take them off your hands.
mrholeshot
MEMBER EMERITUS
If the shaft didnt twist and build energy it wouldn't make a differance but when the shaft twist it makes a differance. Like counter steer you just have to do it to prove it.
