Vise Stand
VegasBruce
Just outside Sin city
I needed a new stand for my vise, so I whipped one out today.
5x2 1/4 wall tube, a 19" flange cap and some tube to hold a few hammers.
V
VegasBruce
R6 Racer
Northern Ontario Canada
Look great!:thumbup: Luv the hammer racking!
I'm curious... do you find with an 80 pound base the vise is stable enough? I would have thought that you would need something a lot heaver. Like a couple hundred pounds or so. I'm looking into something similar & I do like your idea!
Anyone else like to comment on base weight?
Steve
V
VegasBruce
Steve
It is a little light, but its good for most things. I have a 200 pound stand in Texas that works great. I can always bolt it down if necessary.
how much was that base ?
It was something I picked up out of the scrap pile at work.
Brad54
I was in a resto shop that had several light-duty vise stands made with a space-saver spare tire as the base. Small-ish vises, on a light-duty stand, but they were a HUGE help to the guys in the shop--they could quickly and easily move them over to the work area, hold parts while they were persuaded apart, or used to bend sheetmetal flanges, etc. etc.
Real handy in a big shop with a lot of guys.
The shop put one at each guy's work station, which saved time because they didn't have to travel from the project across the shop to the big bench vise and back repeatedly.
-Brad
N8
In a house
Great looking stand Bruce. Clever for the hammers.
Looks like a good selection of BFH and body dollies.
I'd love to see what that 10 spoked rim is attached to!
Almost looks magnesium.
N8
V
VegasBruce
N8
I like it. came out great and good choice of color as well.
Thanks guys, it turned out pretty well.
N8, the wheel is just the wife's Sportster.
V
VegasBruce
I like it Vegas', good work. Where did you come across that blind flange? Can you post more pics?
It was one that came out of the scrap pile where I worked. I had a couple different sizes laying around. This one was the biggest one left. I'll go out and snap a couple more pics tomorrow.
The truck brake drums would work too. You could also cap the bottom and will them with sand. I just need to find a source for them.
slip knot
Texas gulf coast
Mounted mine on some 4in perforating gun with 13 bags of concrete. Its pretty solid but not too portable. Kinda like the stand idea. may have to make me one of those for my next vice. Have to see what knida blind flanges I can scrouge up at work.
V
VegasBruce
Very cool, after using a stand mounted vise, it would be real hard to go back to a bench mount. :thumbup:
V
VegasBruce
ok, now i gotta see the stand you got for the RR track anvil.( in the background) Been looking at doing something for mine.
I ran out of blind flanges, so I used an old GM flywheel. The same 2x5 rectangular tube and some radius gussets. I'll add something later for a couple more hammers.
reinhardt
i am curious of the painting process you used. i built a work bench from angle iron and it still has mill scale and rust for a top coat. did you sandblast? what kind of paint and primer? it looks nice.
V
VegasBruce
Thanks, I just hit it with a wire wheel to knock off the big chunks, and sprayed it with Rustoleum. Nothing special, if it starts to look to bad I can just respray.
t100
"old" bandsaw stand works great. this old girl is made of stamped 1/8" steel, weight a ton yet strong as hell.
reinhardt
forgive my many questions on such a simple thing.... did you prime it? rustoleum spray paint cans? sounds so simple. i just fear rust bleeding through and paint flaking. thanks again for your time.
ben
GeorgiaHybrid
Extreme NW Georgia
Neat,
A vise growing stand. You put the little ones on the bottom shelf, sprinkle Miracle Gro on them and they grow up to big vises on the top shelf....
V
VegasBruce
ben
Ben, I used an angle grinder with a wire wheel to knock any loose dirt and rust. Then just Rustoleum spray cans. No primer or any special prep, it it peels or anything I'll just do the same thing over again.
472scout
back 40
Right now my vise is mounted to my bench, but I plan to weld up a dedicated stand for 360 degree work clearance. The bench just gets in the way too often. When I get it done it'll get bolted to the floor as I know soon or later I would push it over unless I make it ungodly heavy.
I do have my grinder mounted to a 100 lb freestanding base (2" sq tube and brake drum) and even for just a small el-cheapo grinder that is a little on the light side. The round base is handy for rolling it around the shop.
