KnightFire, did you use any clear-coat on the top. This does not look to have the gloss look that you see with other products? I am looking for that high-gloss finish and don't see it here in your project. Feedback please. Thanks
I sincerely did not mean to slam the competition.
Please consider this .... if I had just told you that we switched from POR-15 to KBS Coatings, you would have asked, "why did you switch?". I just figured it was easier to get it all out with an explanation as compared to leaving all of you with a bunch of questions.
As I said, POR-15 is a good product. I am just trying to make people aware of another option. That's all.
That Makes 9 people in the group buy the more people the better the discount. there will be a time delay on the orders due to people requesting color samples i have finished applying the 2nd coats and waiting for them to dry (notice we dont have any dark gray paint in stock as soon as i can i will make these samples )
Chris... Have you sent the samples yet? My samples from Epoxy Coat were shipped today and I need to make a decision. Thanks!
I called Chris and placed my order this morning. He's waiting to get 10 firm orders before he turns them in.
Chris - could you post a message on this board when you submit the group order so we have an idea when to expect the product? Thanks.
John
I have already PM'd Chris and I trust he will make this right ASAP. Good thing I was not planning on doing this project this weekend!!!!Floor Failure:
Today,
I went out to my garage and there it was- floor failure in three small areas.
My wife is TOUGH on garage floors. She enters and exits like Jeff Gordon.
Still, I was expecting 6 months or more before a touch-up. I repaired the defects in 30 minutes. Second coat this afternoon (will sand lighty between coats) and then two coats of clear (heavy) tomorrow. I have enough product for 4-5 repairs like the one described above.
The concrete below the spots was PERFECT (no old expoxy, no oil, etc.).
I also notice that certain tires leave marks on the floor which require a lot of work for removal. In fact, two times I have needed one minute of epoxy paint removal spray to get the mark out.
These marks occur in my bay and NOT my wife's bay where the failure occurred.
Oh well, you now know that POR 15 is just a fancy, heavy duty paint and NOT equal to a high grade Epoxy. My plan is Race Track next summer if more failures occur (and I fully expect they will).
Value
Value: Can you post pictures of future failures? Would like to see exactly how it fails in your case. Thanks! Jim
But, you have been WARNED that failure is possible and high grade EPOXY is superior. I plan on Race Track next summer over the floor.
Sorry to hear your having problems, Value.
Pics would be great, the next time you get a chance...
Why are you so sure high grade epoxy is superior? I've seen a LOT of commercial epoxy peel in my time. Do you have some comparative experience with epoxy?
this just blows me away. I just spent over $500 on this product and have yet to put it down and I am losing confidence fast. I just spent all day doing prep work and will spend most of tomorrow doing the same. I hope it is not all in vain. If I put this down and 30 days later I have a peeling issue I will be very pissed. You think I was pissed when they messed up my order, that will be like a walk in the park compaired to a peeling issue. WOWthis just blows me away. I just spent over $500 on this product and have yet to put it down and I am losing confidence fast. I just spent all day doing prep work and will spend most of tomorrow doing the same. I hope it is not all in vain. If I put this down and 30 days later I have a peeling issue I will be very pissed. You think I was pissed when they messed up my order, that will be like a walk in the park compaired to a peeling issue.
Value, how many layers of clear did you put on?
This may be a dumb question, however, the "cure time" window that is stated above refers to the minimum time before applying the next coat or the maximum time to apply the next coat within? Quick responses would be appreciated as I applied the first coat this morning![]()
Value....you stated that the tire marking that your car caused happened within the first three days of applying the product. I was under the imprssion that one should let ANY garage floor coating cure for more like 5-7 days before driving on it. Did their instructions say differently?
When I did my floor 10 years ago with Benjamin Moore epoxy, I let it cure for a week before driving on it and only had one tiny spot lift under a hot tire. I'm convinced that it was my prep that caused it as there has never been another.
Relax,
I found the reason for my floor failure: me. I failed to removed all the old water based epoxy. It seems that sanding with 80 grit paper was NOT enough in a few areas. The old epoxy caused the POR 15 to fail. I examined the flakes (looked at the bottom/belly) and found old epoxy in EVERY spot.
THe good news is that when the POR peeled off it took the old epoxy with it. So, the reapirs should hold in those areas.
Again, POR 15 is a good product. But, you need a completely BARE area of concrete beneath it if you plan on parking cars there.
I expect a few more areas may pop up on my floor. NO big deal as the repair came out perfect. Also, I didn't add the grit/sand to my repair as this may allow less contact between tire and floor. Yes, the floor would be slippery but the tire is less likley to cause failure (in my opinion).
I like the POR 15 floor. I will keep you updated. But, my Mercedes Benz tire did cause two spots to have a PERMANENT tire mark on the floor (not a failure). This occurred 3 days after completion of the project. While I was repainting the the bare spots I sanded those areas down and repainted them as well.
It seems aggressive tires like a sports sedan requires 4-5 days drying time even in my humidity.
I am happy with the color and the product. If I had bare concrete I would use the product again at this point. For those with old paint or epoxy you must get that stuff off in all areas where the cars are parked.
Value
