HF Air riveter
dodge610
North Canton Ohio
Anyone bought one of these and used it im thinkin of buying one and using it when i do bodywork or restoration work on one of my many restorations thank you in advance.:thumbup:
nissan_crawler
Wichita, KS
I haven't personally, but I know several people that use them to pull cherry rivets on planes.
D
dodge610
North Canton Ohio
Have they said how they work i do not want to invest in one then have it jam up and spend more time un jamming it than i do using it of course all of the reviews on the HF site all say how good it is wonder why that is huh.
nissan_crawler
Wichita, KS
They haven't complained about it. I'm sure if they had issues, they wouldn't use them, as they're only 200' from $1000 cherry guns.
D
dodge610
North Canton Ohio
Thanks for the insight think i may stop next weekend and pick one up for myself worst casr scenario i can do a thred on how it passed or failed thanks again.:beer:
Ray-CA
San Diego CA
I bought one several years ago when I started building my FFR Roadster (cobra.) Not only did it pull all the rivets in my car, I loaned it to three other builders so they could use it.
Ray
Dan in Pasadena
Pasadena, CA
Just curious, what do you guys use rivets for anymore? And what do you use SO MANY rivets on that you need a pneumatic riveter for?
I have a manual pop rivet gun but frankly, I've never used it.
Stephenw
Utah
Let me see you set a 1/4" rivet in a door window regulator by hand.
D
dodge610
North Canton Ohio
I restore old mopars and sometimes i have to make my own alum body parts by hand some i rivet some i weld either way i will use it some of the old interior dash parts on the 57 plymouth ill be workin on are gonna need hand formed and rivited in place.
Stephenw
Utah
Hey, it wasn't a challenge, chillax.:)
A window regulator? I can't think of one I've even seen since I used to have crappy steel casement windows and they didn't have rivets in them.
I mean a window regulator inside a car door. Many are riveted into the door.
t100
basic rules for pop rivets: the tighter you pull, the stronger they are. pneumatic guns are always pull harder than by hand. we use a lot of them on aluminum and carbon panels on race cars, .
D
dodge610
North Canton Ohio
There you go dan two guys that use em on cars more than likely a lot more and no we do not need to chill you asked we are tellin :thumbup:
PCO6
Newmarket, Ontario
I built a utility trailer and riveted the aluminum panels to the steel frame (with rubber strips in between). I used the attached riveter for the roughly 200 rivets. It was a lot easier than using screws and resulted in a very professional look. Based on what I've read in this thread I wish I had used an air powerered riveter.
http://www.princessauto.com/worksho...ools/fasteners/8309239-21-long-handle-riveter
Mike B26
Green Bay, WI
I bought the cheaper one in August. Actually, I bought two in case the first one took a **** in the middle of the job.
I pulled around 4000 rivets with it over the weekend and only had to adjust it a few times (maybe every 1000 rivets or so.) For some reason, it didn't shoot the mandrels out the back and they would just drop out the front, but it was a minor inconvenience.
I returned the 2nd riveter on Monday. :thumbup:
D
dodge610
North Canton Ohio
Agreed you can get the hydraulic air rivet gun at HF with a 20% coupon for about 51.00 less than the hand rivet gun at princess auto live and learn i guess that is why i luv this forum a wealth of knowledge from each and every person.:thumbup:
PCO6
Newmarket, Ontario
We don't have Harbor Freight (or its discount coupons!) in Canada. :( Princess Auto has the same basic unit for about $65.
BTW ... here's another "rivet" project. Except for the stand which was welded together, this is basically galvanized sheet metal and rivets ... and a few tubes of silicone sealer. :)
usdemt
South Dakota
If you own a snowmobile its almost a mandatory tool to have, I dont know what I would do without my pneumatic riveter. I got mine from Summit Racing and love it.
I use mine for a lot of random things as well. Some guys dont think about a rivet but once you use them a lot you will find perfect applications for them.
Red Green
South Central Michigan
I have the one that was 39 or so five years ago. I have done thousands of rivets with it. I have had to take it apart twice I think to clean the jaws.
I use it for race car bodies. I would guess there are about 100 or so rivets in each car.
gkring
Keller, Texas
Here's what I use for 1/4 inch door regulator rivits. Sometimes you need the forward facing long nosepiece to fit in certain doors. Sounds like the HF one works pretty good. Something to spend a 20 off coupon on since all the big ticket items are excluded now.
chubby one
While not a HF riveter we use one to build aluminum dirt track bodies and interiors my son did not want to spend 50 bucks on an air riveter till we started on his race car then I handed him the hand riveter he popped 2 by hand and picked up phone and ordered an air riveter now he flips out if we can not find it in shop it is a must have tool in my opinion.
chewy7
WISCONSIN
"I like the "third hand" method ...
http://www.youtube.com/watch?v=d_9k9...eature=related"
lmao
kmacht
Connecticut
I am building a 2 person aircraft called the Sonex from plans. It uses about 9500 pull rivets in its construction. These are structural stainless steel pulled rivets, not the cheap hardware store ones. I bought one of the harbor freight rivet guns when I started for $35 on sale. I am now around 7000 rivets in and it still pulls great. If you have trouble with them, a few things to check. First make sure that the oil level in it is correct. Second, sometimes the nose piece that holds the two wedge shaped teeth that grabs the rivet works loose. You will know it is happening when the rivet gun pulls the rivet but won't eject the stem. Just open the nose cone, tighten the nut, and you are back in business. Also, play with the air pressure you feed the gun. I find that 60psi works well. If I go all the way up to 90psi I sometimes get smiley faces around the rivets from the gun pulling a little too hard too quickly. In any case, the gun is a great deal.
Keith
jhelrey
MN
Snowmobile tunnel, bumper, etc... Bumper alone at 26 rivets.
jhelrey
MN
PS: The HF Air Rivet Gun for the WIN!!! I had to update my snowmobile tunnel from the curved failure of a design to the correct one. I wanted to do it myself. This is what it looked like with everything removed ready for the new rear tunnel section.
Mastermind
Ypsilanti, MI
