Whatchamacallit ?
wheelsup60
When you are opening a canopy and sliding the legs open a ball pops into a hole to adjust the height.
It is a spring and ball assembly. What's it called ? Where can you buy them?
Can you get them in much larger sizes?
ddawg16
S. California
As in the detents on an Ez Up?
If so....you should have said something last week....I just threw away a bent ez up frame
W
wheelsup60
Detents ah yes that's it. Looking to build a Bench Grinder mounting assembly that lowers under the work bench for storage.
I know mounts have been talked about on here before but I want something different then using a trailer hitch receiver etc.
Thanks
senlow
Wheat Ridge, Colorado
That type of detent is known as a spring button. I have some spring buttons (a couple diffreent sizes) that are surplus from a product that I used to make. I'd be happy to send you a few to experiment with. If you want some just send me a PM.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Case IH
Green Bay WI
If you go to e-z ups website im pretty sure you can orded specific parts if you need them for that.............BTW you havent lived until you have seen a E-Z up go flyin across a karting paddock at 40mph due to winds and not tying them down..
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
There is a thread here somewhere about a shop in the UK with several nice tool storage devices that raised and lowered to store under a bench.
carap
OKC
McMaster Carr has them. Don't know exactly what they list them under.
