Oil Filter Wrenches?
bart1
Alabama the Beautiful
I use this Hazet model 2172:
http://chadstoolbox.com/hazet2172oilfilterwrench.aspx
It works on all makes, all models, all sizes of filters. Yes, it is VERY expensive (I have had mine for about 25 years), but it never fails and gets off even the tightest filters.
That's one of those Hazet things I would love to buy, but my Craftsman one was 10 bucks or less, and quite durable. As such, I just can't justify it. This one is made by Lisle apparently. It works in tight spaces, but tends to damage, or even puncture, the filter. I prefer the socket type, but they don't work as well on tight ones.
http://www.sears.com/shc/s/p_10153_12605_02820523000P
L
littletoes
NE Washington
I have this same tool, and don't care for it. Slips like crazy on smaller Honda filters. Even wrapped it with electrical tape, to try and make it grip a bit more. I use the single band type. It doesn't slip much, and I get 'em off. Use it with a stubby ratchet.
I don't mind spending the money if it makes my life easier. Over the years, if it saves a bit of cussing, its worth it! ;)
bart1
I'd sugest getting some sticky back sandpaper and putting that on there, or better yet, sell it to me cheap ;)
Moose-LandTran
The Brink of Insanity (England)
That's becase those Honda filters are the minimum size that can grip. I have a cup socket for them for that reason, the spiders slip. Had one the other day where the spider just slipped and wouldn't bite. Out came the socket and off came the ******* filter.
jayoldschool
Canada
I use the large and small versions of these things. Work well, haven't had a filter that I couldn't remove yet.
caper
cape breton
I mostly do diesel medium duty trucks,grab my large channellocks and take them off.Rarely need anything else.If I get a stubborn one I use a Snap on strap wrench,1/2"dr.
Moose-LandTran
I've used my 18" and 24" pipe wrenches a few times on really stuck filters. It's not unusual for me to use an 18" ratchet with a big filter socket, it seems a former employee of where i work used to tighten filters as tight as he could.
jvitez
Big Sky Country, Canada
If you have a "*****" filter then this little jewel will flat take it right off:
These have been discontinued for several years. Make that a few decades. Actually Elroy broke his at one time. Presented it to the Snappy man and he just laughed real hard. Long discontinued.
It's good to go now but most vehicles today have the small filter cans so this tool now see rather limited use. When it fits the can, this wrench has NEVER failed :thumbup:
Wow Elroy, I thought I was the only one with one of these. I purchased it about 15 years ago. I had a 94 Yukon on which filter access was quite difficult due to the 4WD front drive shaft. I fully agree. No filter has ever beaten this wrench. But it is too large for most modern cars.
However, I've found a new use for it: my 2006 Dodge Ram Cummins. On my 98 Cummins I could reach the filter through the engine bay. The 06 requires under vehicle access, and it's a loooong way up when on jack stands. So, a socket wrench, 2 extensions, and this filter: pop, off it comes. And it hold the filter very tight so I can keep it upright and not spill a quart of oil on my torso. Excellent filter wrench!
handyvorb
AL, USA
I use Channelocks oil filter pliers http://www.channellock.com/Category.aspx?zcid=109 .They work as long you have room to use them. We have this model http://www.channellock.com/215-Oil-Filter-PVC-Plier.aspx that works on larger truck and tractor filters. I also used this model on my 2004 gmc truck with (5.3 liter V-8) to take off the oil filter.
These are what I use on a daily basis, all other oil filter wrenches (except factory fitted sockets) are inferior IMO.
bobbyrae
Alameda, CA
I looked that thing up: $123?? Man! I found this similar one by Toptul and it only costs $13. Normally, I use the band type and find that they work so well that I don't need to think about any other approach. I am thinking about trying the Toptul since it would be so universal (AND it's low cost).
Anyone have any experience with this thing?
BTW, I once bought a K-D oil filter wrench band type that had three hooks on it for the main three sizes. The trouble was that on the big filters the hook for the smaller size digs right in and punctures the filter! I don't think any oil filter wrench should destroy the filter by design. But that's just me.:willy_nil
bonneyman
Desert SW
I've used Fram oil filters for years, as they have the bottom half coated with some black rubbery coating. Makes gripping it with a band filter wrench a piece of cake.
Though, I'm thinking of switching to K&M, as they are supposed to have 1" hex nut welded to the base of their filters. Alot less hassle,but, then again, I'm the only one doing them. They won't be put on uber tight.
Dave455
Sussex, England
I've got a Facom wrench with a steel step that tightens really tight! Think it was designed for the Renault 16 (that dates me) but it works better than anything if you can get to the side of the filter!
If you can only get to the end I use Stahlwille oil filter sockets!
L
littletoes
NE Washington
TRULY! Thanks for the Honesty, it a welcome breeze. :beer:
I bought the K-D brand of cup-sockets for the Honda filters, and they work, but the cups stick, and its hard to get them off the filters without a punch. Maybe a higher quality cup? Just haven't bought one yet. I know not every tool works for every application, but when one works, it's nice to have around!
Good Luck out there guys!
celticbhoy
I mainly use this:
288956
but I also have the channellock oil filter pliers as well and the three prong wrench that goes on a ratchet.
demoric
I use Channel Lock Oil Filter/PVC pliers for my Mustang, and one of the 'socket' types for the wifeys ride.
The Channel Lock Oil Filter / PVC pliers are what I use all the time. I have 2 different "socket" types and haven't used them yet in 7 years. Although I probably should have tried it once. I had to do the ol' stab the oil filter through with a screwdriver and twist off. Then I remembered I had the socket. Whoops.
MellyVan
I've been using these for years. Inexpensive (5-10 usd) and gets everything off:
USA Tool Supply
Midwest
I don't know if this will help but "Lisle" brand offers a filter socket set # 13300 that are low profile. Included sizes 24mm, 27mm, 29mm, 32mm and the 35/36mm. I believe you can pick it up for around $ 50.00.
priceman1414
Midwest, USA
This is one my father has - it has Craftsman stamped on it - turning it to loosen with a 3/8" drive will tighten it, while turning it to tighten will loosen its grip.
wafrederick
Holton,Mi
I have a pair of 22 inch Knipex Cobra pliers for the very tight oil filters.Oil change places,some love to overtighten the oil filter.I have one special socket,the oil filter socket for the GM ecotecs.
L
littletoes
NE Washington
Of course it helps! ;)
That's what this site is all about, giving our ideas on tools, and letting each other know about deals that we know and hear about. Plus, we just plain like tools too!
Welcome aboard! :beer:
