Hauling a Compressor
70ss
STL Area
Quick question, can you haul an air compressor on its side with no ill effects.
Edit: Is $900 for an ingersoll rand 7.5 HP 80gal. With the full add on package: after cooler automatic drain... that is a few years old a good buy.
kams1973
Amarillo, TX
If you do lay it on it's side with oil in it, roll the pump over by hand before powering it up. This will ensure oil did not seep past the piston rings.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
What I was told when I picked up my IR 80 gal. compressor was to let it stand in an upright position for a few hours so the oil would drain back down. Same for a fridge, let is stand for a few hours. I've never heard the 24 hour thing. If that oil can't drain back in 2-4, I don't know what another 20 hours would do. Aside from that, I have never had a problem with any compressor or any refrigerator that I have ever hauled.
intimadatorsquizz
Telford,PA
Ditto
70ss
STL Area
Bump for edited question. I think I will just lay it down then wait to run it. Unless I can get it in the truck upright somehow.
MotoDave
Ventura, CA
I just hauled my 60 gallon CH compressor home from Lowes a month ago on its side since my truck has a shell that's too heavy to take off by myself. It stood for a couple of days while I finished the wiring, and has worked perfectly since. I did note the oil level in the sight glass before and after the trip and it didn't change.
38Chevy454
Cincinnati, OH
This is good idea to make sure it rotates easily after letting the oil drain down for a few hours.
930dreamer
Amarillo,TX and Stinnett,TX
This one must have been on it's side before it got it. I just removed all the lines, drained the oil and runs great.
38Chevy454
Cincinnati, OH
What, So IOW to tell if there is not something like a hydraulic lock up?
Thanks, Tony
Yes, turning it over a couple revolutions by hand will ensure you don't have oil trapped in the cylinder. Oil should stay on the crankcase side of the rings, but why chance it?
rsanter
visalia ca
if the compressor is used, then just drain the oil
I would want to start with fresh oil in it anyway
bob
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
Thanks 38Chevy454,
Tony
bob
Yeah good point, cept for when I brought this little one home for $75.00.
The oil was like brand new looking.
Thanks,
Tony
