mkdive
Ok so I wanted to try a new method of cleaning up some of my rusty tools. I as many of you, I dont like to wire wheel any of my tools. I wanted to find a way to clean my tools that have rust that didn't require caustic chemicals, tons of scrubbing with wire brushes etc. So I did some Google searching and found that maybe I should try electrolysis? I did some searching on GJ and only found two threads that even mentioned the process..... (maybe I need to work on my searching skills). So I thought i would write a thread and post back my thoughts on using electrolysis as a de-rusting method. You know I had everything this process requires in the garage & kitchen pantry(as most of you guys probably do also). It took me about 15 minutes to throw together a "dunk tank" and get it going. After about 40 minutes to and hour of soak time the results were amazing!
Here is a link to a great website I used for reference on the DIY electrolysis process:
http://www.<wbr>rickswoodshopcreations.com/<wbr>Miscellaneous/Rust_Removal.htm
Here are "before" pictures of the wrench I used for testing:
Here are the "after" pictures:
The last step (to clean the remaining black oxide), I need to find a better tray for the lemon juice/soda or hydrochloric acid bath. So I just soaked the box end of the wrench in a small plastic cup of lemon juice I had. Wonder if white vinegar would work?
I think I will run to target or walmart and get a plastic coated cookie cooling rack and use it to set the tools on. That will work a little better than the plastic lid I used.
Here is a quick video I threw together on the crude setup I used. Please excuse the extremely amateurish video. I'm great with DSLR's, but its painfully obvious I'm not too proficient at video or video editing for that matter.
<object height="745" width="960">
<embed src="http://www.youtube-nocookie.com/v/9AhKbEL86UM?fs=1&hl=en_US&rel=0&hd=1&color1=0x2b405b&color2=0x6b8ab6" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" height="745" width="960"></object>
