Finally Building My Detached Garage, Build Thread
Gareth
Lancashire, England, UK
I went back and forth between the two and decided on the RaceDeck. At my last work, they had a very high end epoxy and as soon as you drug something across the floor, you now had a nice big scratch. With the RaceDeck, when one gets damaged enough to replace, you can replace with no problems.
But for the most part, I liked the idea of having the floor match the rest of the garage and it "looks" nice, at least IMO.
I was always planning on epoxy for mine, but I'm having second thoughts due to the reports of damage from welding and from jacks and axle stands. I hope to do a lot of work out there, and I don't want to be paranoid about the floor. I'm actually considering just putting down a decent quality floor paint, and then being prepared to re-do it every few years.
Awesome garage - you have done a fantastic job.
K
KYGTP
Greater Cincinnati Area
I just joined this site. I am getting ready to pull the trigger on my garage
build. It took me awhile to read all ( or most ) of the 34 pages. What a great
build. It got me thinking about alot more details. How is the compressor
room working? Is it getting hot & is it getting enough air? Is it quiet?
How is the racedeck for rolling the motor crane & tool box's onto? Sorry for
all the questions but it's all stuff I took notice to on your build thread.
I don't see the Subaru in the garage. I'm into Subbies. Thanks.
The compressor rm is nice and I have not had it running a whole lot, but from the little bit that it has run, Ihave not noticed any heat build up yet. It is quiet enough that it does not drive you crazy when it it kicks on while you are working, but when you open the door, there is a big differece though.
Rolling stuff over the RaceDeck is pretty easy. My largest box, which is the HF box and a craftmans top box total full has no problems rolling over the floor.
The Subaru is a friend of mine that is staying with us right now, so it is not mine, but it is a very fun car though:)
Thanks
If I was you, I would just wait until you can get what you want. Paint is going to scratch really easy, WAY more so than Epoxy.
Buzz Lightyear
Wiltshire, UK
Thought I'd just call in and say hello :D
It's looking amazing. I've not been on the forum for a while but your build is still looking fantastic.
K
KYGTP
WOW! i just finished reading up on the whole thread, and all i gotta say is WOW!
Thanks a bunch!!
BUZZ!!! Thanks for stopping in, it has been a while. Hope all is well......
I got some more pics of some stuff I have done that I need to get posted when I can find the time. I am hosting a big Super Bowl party in the new garage, the first big party for the new space. So I have been a little busy finishing up some little things.
Buzz Lightyear
Wiltshire, UK
I've been a bit busy with the new baby who arrived on New Years Eve but I'm back now.
Looking gooooooood.
chevy265
Pa
I have been looking at GJ for years as a guest,I had to join today to tell you that you cost me a good nights sleep with your 35page build! :) All i can say is WOW!!! I have a couple suggestions, if you remove your compressor's air filter and run pvc outside with the filter on the end of it, you will be amazed how much quieter it is. My buddy can now talk on the phone inside his body shop when the comp is running and its not in a seperate room! The only thing i saw that i didnt like is the incandesant drop light! I have an uncle that not only burned his shed down but burnt himself pretty bad. I also have a friend that lost his house and attached garage full of goodies. both of them had fuel spray on thier droplights. I threw all of mine away and got led's. I am not the type to blame a product when something happens, I know its common sence to keep a hot light away from fuel, but if its not in the building it cant start a fire!!! As an added bonus you will never burn your arm when you bump it on your led lite! sorry so long but i really dont know why there still making those lights! Keep filling that building up,its not like your gonna hurt the foundation! lol
K
KYGTP
Hey all, I know it has been a while, but been pretty busy.
I did got more things done in the garage and getting settled in some what. I got a entertainment center from Ikea that looks like a tool box, you know, to go with everything else.
I also ended up finding some bar stools at my local Big lots for cheap, and they are built pretty good considering..........They worked out well for the superbowl party that we had.
I got around to hangs some signs in the bathroom and in the garage, the little bit that I had. I also got the "Walk" / "Don't Walk" light up too.
Here are two shots of my car in action at the track that a freind of mine got for me:
Even though I had all the surround sound speakers hooked up for the sitting area, I still had the other 6 speakers in the garage to hook up. I just had those wires sticking out of the wall and I needed to figure out a way to clean it up.
So, I went to hardware store and picked up a 4 gang box cover to use as my mount and then headed to Radio Shack to pick up speaker terminals to mount to the gang plate. That way I could hook all the wires up to the terminals in the wall and then run short wires to my receiver. So this is what I came up with:
I took one of these
And Turned it into this:
Now to sort out all the wires and get them hooked up:
You can see in the background of the above pic with my notes as to what is what and how I was going to hook it all up.
Here it is all finished up and installed on the wall:
Once it was all hooked up, I wire loomed the wires together leading to the receiver for a cleaner look:
After working on a couple of small projects on my work bench, I realized that It would be nice to have some task lighting, so I installed 6 puck lights under the cabinets to help with that. I pulled power from one of the plugs, ran that to a switch with the oulet outlet on the top of the cabinets for a nice clean install.
That is what I have been up to over the past couple of weeks in my free time, doing a little at time, as I get the time.
I must say, I have LOVED using my new space, my wife and I find ourselves out there hang out more and more, almost like a second living room.
Well everyone, thanks for looking again and when new things come along I will post them..................................Till next time.
K
KYGTP
awesome garage!! what toys will it be housing?
Well, as of now, I only have one toy, and that is my 98 Grand Prix GTP that I have modded pretty heavly. I bought the car new in 98' with only 200 miles on it and was my daily driver up until about 5 yrs ago, what is when it turned into my project car. I race 1/4 mile for fun and have with the car for over 10 yrs, it has just gotten a little more modded over the past 5, with larger cam, heads, PP intake, Eaton Gen V SC, smaller pulley, eletric water pump, oversized SFI balancer, larger IC, Roller Rockers, Headers, Custom build FWD trans with a Torsen Diff and a bunch of other goodies.
The best that I have been able to get so far is only a 11.70, but not bad I think for a FWD car that still weighs in at 3200#. If you look at my post above, you can see the framed pic of my car doing a burnout in the burnout box. Its fun and it is different than what is out there at the track.
BUT, some day, I would LOVE to own a Porsche 911, I have LOVED those cars since I was a kid...............In time I hope to get one someday.
imahemi
Omaha, NE
sweet space!!!! i have followed this for a while...
one question as it may have already been covered. why put the media room/area in the garage vs putting it upstairs??
K
KYGTP
Well, the upstairs has all the rough in everywhere for all the plumbing and such for a apartment some day, and the ceiling height is only 8.5'. Due to Zoning, the garage could not be any taller than my house and I wanted the garage to have 11ft ceilings, so that brought down the height of the upstairs ceiling. It is also a little over half the size of the garage.
Plus, I wanted my wife and son to be able to hang out in the garage with me if I am working something. With the sitting area down in the garage they can play X Box, watch tv or what ever while I pittle around and still be with me.
This past sunday I had a bunch of people over for the superbowl in the garage and it was very nice to have all that space to hang out and watch the game on the 110" screen. The first real party for the new garage and now everyone that was there is now coming over to watch the Daytona 500 in a couple of weeks. Looks like I am going to have alot of get-togethers now, which makes me happy to share the space with my friends and family!! That is what it is all about, IMO
So to make it a simple answer for ya, the space.
imahemi
Omaha, NE
easy enough :D more a hangout space with a big screen!!!!
K
KYGTP
KYGTP,
Any progress or additional pictures?
Well not much really, just added a couple of misc things on the cabinets and such. Finally went though all of my stuff that I threw in boxes from the house garage and got all of that orginized.
But so far I have had a Super Bowl party and people of for the Daytona, all of which was a blast to be able to use the space for parties and work on my car.
During the Daytona, a couple of friends of mine and I put the motor back into my Grand Prix and got everything installed and wired up and by the end of the race we were priming the motor. Pretty darn cool.
I will post up some pics here soon of some of the little stuff I have done.
I hope in the spring to have all of my contractors over for a little get together so they all can see what came of their hard work!!
Qwk
I hope in the spring to have a little get together!!
Sounds GREAT! Ill bring some Burgers!!!:beer:
shopnut
Florida
An index has been created for the Garage Gallery build threads and I submitted yours on behalf of the Garage Journal community. We are trying to capture as many inactive threads as possible so I hope you don't mind. It will serve as a placeholder until you log in and check it for accuracy. Should you find errors, you can easily submit your own entry and mine will be deleted.
Drop in and give us an update if you have a moment.
GregJW
Norman, OK
Amazing. Do you have any pictures of the outside with a few years of trees and grass growing? Love it!!
K
KYGTP
Well, it has been a couple years, and WOW how time flys by. My garage has been one of the BEST investments I have EVER done. Working on cars with friends in a climate controlled environment has been so wonderful. Not only that, but when my cousins come to visit, two of their sons stay out in the garage, sleep, play xbox, shower, eat, they love it.
Over the past couple years, both my wife and I have gotten into doing HDPEs with our cars. So having the garage with the lift has made prepping the car for the track so easy, changing brake pads, bleeding brakes, changing oil, and changing wheels, ect....
So on to your request for updated pics of the outside of the garage:
Just for the heck of it, here are some shots with the doors open:
The inside is a little cluttered at the moment, which I don't really like, but we are getting ready to do a motor swap in the Grand Prix and get it out of there.
Anyways, here are some inside shots:
So there you have it, a update several years later, hope you guys and gals enjoyed. Thanks for looking :)
sean Buick 76
Edmonton Alberta
Very cool, thanks for the updates! I have a lot of respect for the Supercharged 3800 engine in those GPs... I had one and it was super reliable.
K
KYGTP
Yes they are. I have beat the chap out of that car. I used to drag race it and we had a blast with it. The best I could get out of the car was 11.49, and that was with a built motor and trans. Since doing the HPDEs, I have not kinda lost interest going in a straight line for 11 secs at a time. Being on a road course for 30 mins, now that is a blast!!
My Friend and I have built a GP with a turbo, and we were able to get it to a 10.48 in the 1/4 mile. We hope to get it into the high 9s by the end of this season.
Thanks for the comments though on the garage, it has been a blast!!
Zengineer
British Columbia, Canada
LOL!
Your neighbour with the door out of the back of his place to nowhere (For those who didn't see, look for the neighbours house photo near the 1st few pages of this thread) finally figured out how to deal with the door to nowhere.... put a trampoline under it!
GregJW
Norman, OK
A door to a trampoline! Hahah
So you track the GTR? Great car!! I didn't see that's before!
It looks awesome. The garage, retaining wall, big driveway, etc defiantly one of my favorite shop builds on garage journal. I would say the greatest practical car guy shop builds I have seen.
K
KYGTP
Thanks for the complements on the garage!! It was been a great asset and investment. Now I just wish it was a little bigger :)
Yes, we track the GTR and the STI. I starting tracking the STI when I got it new, I think it had 1800 miles the first time it saw a road course. Then when I moved up, my wife came with me a rode with me and feel in love with riding. Then we wanted a fun weekend car, so we got the GTR.
Next thing I know, my wife is in the GTR on the track and having a blast. So now we take both cars, she drives the GTR and I drive the STI. I do take the GTR out in my run group though to just enjoy the amazing power it has, but I am just glad she enjoys it as much as I do.
Here is a video of her on the track in the GTR: (She made the video)
The GTR is a beast on the track and we have a blast with it. We bought it to drive on the weekends for dinner and beat the eyes out of it on the track. Just driving it the way it was build to be driven. Seeing over 140 mph down the front straight, and hammer on the brakes in 250 ft to take turn one is one heck of a rush :)
Boosted1
Georgetown, KY
Great update KYGTP.
Love the video too.
I see from your toolbox you have some SPL parts. They make great stuff.
I have alot of their pieces on my 300TT. Very good quality stuff.
GRN96WS6
SOMD
Nice place there, shocked your HOA allows the trailer to be in the driveway.
K
KYGTP
Great update KYGTP.
Love the video too.
Yes, I have a lot of SPL parts, most all the suspension parts on our GTR are SPL. Front upper control arms, Rear control arms and later arms. They have held up great, considering all the abuse we are putting them through at the track.
Thanks. The reason I can park my trailer there, is that we have NO HOA. :) I am off a private drive that both myself and brother share, so we are not in a subdivision. Pretty much can do what ever, with in reason, since we are still in the city, but on the very edge of the city.
When we built our house, that was one thing we did not want was a HOA. We lucked into this property, and it has been great.
K
KYGTP
Fantastic garage! Having no HOA is such a plus, too. Just watched the video of your wife in the GTR. Nice to see she doesn't baby it!
Yeah, we don't baby the GTR. Pretty much once her or I get in the car on the track, we drive it like we stole it. But hey, that is what the car was made to do, preform on the track, and we take full advantage of it. Very fun and safe car to drive.
ambenz
NW Chicago Suburbs
Thanks for the update on the finished product, your insite and thinking and dreaming large has been fulfilled!
Very cool design and execution...Nice!
I wish I had the property to go bigger than my 22X30 but you do what you can with what ya got.
Your build is a good lesson for those who are thinking of building a garage in that, you need to put all the things you want into you dream garage and then downsize on what your budget can afford.
I saw on this forum, someone installed electrical conduit under the driveway even though they couldn't afford to bury there house wires...I did the same and 5 years ago finally got my power wires to my home underground...it was a smart play!
So I am thinking, is there anything you could share with us that you might have done differently, added now that you could have when the build started...any regrets on what you didn't do that you should have thought about???
Inquiring minds wanna know!
