Favorite spray lubricant
BiltFordTuff
really it dont matter to me, as long as it breaks loose that "rusted up for 10 years" nut without tearin up something
ishiboo
Oshkosh, WI
PB for rust, generic white lithium grease or silicon (depending on application) for lubrication, Boeshield for protecting :)
mrchuck
Gun Barrel City, TX
I use more Liquid Wrench than anything on old tools, because it is cheap.
For inside lube I use a mixture of Corrosion X and Slick ! lube that I put in a small squeeze bottle with a needle tube.
For ratchets inside, I use the clear Super Lube.
I have ordered 2 spray cans of Kroil to try.
The absolute best penetrating fluid you can use is a 1/2 & 1/2 mix of ATF and Acetone.
I do not use this often, since I have no tools that badly rusted.
crewchief888
NW indiana
for general lubrication i have no clear cut favorites
most general rust breaking i go with pb blaster, i have just recently started using sili-kroil.
gonna have to get some more of that stuff, it seem to be the best at rust busting so far
:beer:
oldgoat
Wichita Kansas
I use the PB blaster for rust, but for general use I also have regular old WD40 around. If nothing else it is good for spraying into the carb on small engines to start or when adjusting to stay running.
Stephenw
Utah
In aerosol...
For a really light lubrication, the body shop's best friend, silicone spray.
A general light oil to lubricate and protect is Break Free CLP.
A heavier lubricant is white lithium grease.
Skin
Boston
My favorite and most effective.
trbomax
starvation lake,mi.
Kroil to bust it loose or as a penetrant
Tri Flow as a penetrating lube
Amsoil heavy duty metal protecterant for chains,bolts not requireing anti sieze,I used to like LPS-3,but havent seen it for a while,the Amsoil stuff smells and looks just like it though
oil based silicone spray (napa has a good one) as a protectorant on aluminum,mostly the suspensions and tunnels of the sleds as it prevents chemicals from staining them. Some silicone sprays use a waterbased carrier and dont work as well.
Busted_Knuckles
Northwest Illinois
CRC "Power Lube", in an aerosol as a lube, its just a light oil.
I'm kinda confused as to why so many of you guys use a penetrant as a lube ? Ive also noticed that with guys Ive worked next to for years, not sure when a penetrant became a lube. I thought a lube was a lube and penetrant loosened up rusty and stuck fasteners. Am I to think that the properties that dissolve rust, also act as a good lube ?
I use Bowman Distribution Penetrant, the stuff is blue and works rather well, its somehow gets down into the rust, I'm not sure they make it anymore. I still have a couple cans of it. I use it on the really nasty stuff, otherwise PB Blaster, for no particular reason.
D.J.
New Haven IL
Maybe I'm wrong but Sili - Kroil for a lube and Aero- Kroil as a penetrant, both from Kano Labs in Nashville TN USA. When not available, or if I feel cheap, WD4O.
Johnny chaos
upstate NY
It used to be pb blaster but I saw a test recently that showed liquid wrench to be more effective??? I can't for the life of me remember where I saw it? I showed the torque before and after the application of penetrant to remove a nut.
4.0 Rambler
Geneseo IL
http://www.chesterton.com/Product%20Documents/TPD/Product%20Datasheets/tdms723_EN.pdf
The testing I've seen shows 723 Spray Solvo and Aero Kroil have the lowest take off torque.
Most penetrating oils on the market
today are designed for multiple functions displacing
moisture, protecting against
corrosion, lubricating and finally,
loosening rusted bolts. The result is a
compromise product. Unlike these other
products which claim to be all things to
all users, 723 Sprasolvo was formulated
to provide only one function; that of
the best possible penetration. Use
Chesterton 723 Sprasolvo when a true
penetrating oil is needed.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
+1 on the lube-penetrant thing. They are two different products.
I use the CRC Power Lube also. For cheap stuff I use the ACE Lube-E which I buy on sale. Teflon and silicone sprays have their uses also but they have hazards that can come back to bite you.
For a penetrant I use PB Blaster first just because it is fast. If the PB fails I use the Candle Trick.
