green.bubbly
My turn finally... steel building home and garage.
The time has finally come to start what began as a silly thought two years ago. My wife and I are going to build a home using a commercial steel building. In the two years that it took to find a piece of land suitable for our project, I have had time to do a lot of research. It seems that this is becoming a fairly popular thing.
What I wish to accomplish with this thread is to share with others that are thinking of doing this. Amazingly, as popular as this is becoming, there is really not a whole lot of information on it floating around out there. I will try and list all the costs and the headaches.
Initially, I was planning one one large steel building with the living area in the front and a garage/shop in the rear section. But due to the higher than planned erection costs and other possible code issues I might face, we decided to do separate buildings. While not comfortable erecting my home, I think with the help of a few friends, we can erect the garage ourselves saving me a good bit on erection costs.
My garage/shop will be a 24x24 steel building. We will actually not be parking cars inside of it as I will have a attached covered carport on the front of the garage. This area will also allow me to roll out any woodworking tools and work outside under the carport cover.
Below is pic of the first and second floor plans. Upstairs will be some storage and a large hobby area for my wife. That will be her area and should keep her out of my shop.
The living room will have vaulted ceilings and the hobby room upstairs will have a french door and New Orleans style wrought iron balcony overlooking the living area. That will also be the balcony I push her over if I catch her in my shop.
The house will be 48 wide by 36 deep and will be a two bedroom/two bath. My floor plans were done using Punch! Home and Landscape. Not the best software, but for the price, it did what I needed and was easy enough to use.
I will try and take a lot of pics of the progress.
So far, these are the costs...
House Permits: $967.00
36x48x12 Ideal Steel building: $14,345.00
24x24x10 Meuller Steel building: $4,895.00
Roughin Plumbing: $2,200.00
Foundations: $11,092.00 ***edit*** now it is at $12,906 due to cross footings and the fact that my original crew bailed on me because they are too backed up with work.
Erection: $5,500
Construction utility pole: $225.00
Total for the foundation anchors is $346.00
***Edit*** 02/19/2011
Garage permits for electrical, water and drain: $220.00
Driveway plastic pipe: $135.00
Plumber charge for garage: $100.00
UFER ground: $25.00 (15 foot #4 bare copper and a clamp)
Sand for foundations: $950.00
Downstairs...
Upstairs...
***Edit*** 06/23/2012
Below are links to threads related to my build. Lots of good dumb questions and great answers.
Metal Panel Screw Spacing
Main Electrical Panel Install
Smoke Detectors
Appliance Wire Size
Cutting Large Holes in Sheet Metal Siding
Conduit Type Discussion
Erection: $5,500
Downstairs...
Upstairs...
Smoke Detectors
Appliance Wire Size
