What exactly do I have here? Norgren water separator?
Kirbot
New Jersey
I picked this up in a boxlot at an auction.
I think it's a water separator for an air compressor, but I really don't know for sure.
So what exactly is it, and how do I use it?
These two things also came with it.
What are they?
dwm
Southeast Michigan
Yes, first is a moisture separator. Other two are regulators (the port on the front in pic 2 is for a gauge).
dwm
Southeast Michigan
So I should be able to use the separator with a paint gun I would assume?
Well... in general that type of separator isn't sufficient for paint sprayer hoses. Of course it depends on what you're spraying; if it's lawn furniture, go for it. If it's a hotrod you spent years building... you need more.
35mastr
Norcal
Yes,But it looks pretty old. I dont know if I would trust that with a nice paint job. Air tools no problem.
K
Kirbot
New Jersey
Well, It would be for when I paint my Jeep.
I'm not going to be too fussy about it, but I do wan't it to come out half decent.
Maybe I'll use it along with an inline "desiccant" dryer and do some experimenting to see how it works out.
larry_g
oregon
I have to ask, is there a number on that first item? Is there a glass or plastic sight glass on the top? If so you may have an oiler....
lg
no neat sig line
dwm
Southeast Michigan
Get what you can afford. Like any finish job, all the hard work is in preparation. Ruining that hard work at the end makes for a bad day.
The typical el-cheapo disposable dessicant canisters don't have much moisture capacity. They're OK for small jobs, but I wouldn't trust them for body panels. At a minimum I'd be looking at a mounted dessicant system. More money than a disposable inline, but still much less than a decent dryer.
K
Kirbot
New Jersey
lg
no neat sig line
There is a number on it, 10-002-010
I'm not sure what you mean by a sight glass, but post some more picures of it tomorrow.
larry_g
oregon
I see on the top there is a small opening, window if you will, that has a tube in it. If that tube is in glass or the window is closed with glass then it might be an oiler. Oilers drip oil into the flowing air for down line tools.
lg
no neat sig line
Pro-Painter
Winston-Salem, NC
lg
no neat sig line
:withstupi
I agree, it looks more like a lubricator then a filter. A real old one maybe.
When it comes to painting, quality filters are very important. Bowl filters are not that good because they restrict air flow too much for HVLP spray guns, but they can be used. It's better to use an in-line Desiccant filter/moisture separator.
For most home set ups, I recommend a disposable desiccant filter at the gun, and a canister style filter with a reusable filter element at the compressor.
The regulators you have will work great for painting. They are the exact same type found on pressure pot paint sprayers.
cnc-me
MI
That's defiantly an oiler.
See the filler cap at the top, a filter would not have that.
Most oilers don't work very well, especially when you have a long hose attached.
In my opinion the ones made by Bijur are the only ones worth having.
K
Kirbot
New Jersey
Alright, looks like I'll have to find something else to use for painting.
An oiler certainly would not be of any help!
So, Is it worth listing in the classifieds?
I really don't need it.
Vicegrip
NoVA.
top is an oiler, I have used ones just like it in the past. You dial in the drips per min, or min per drips, by letting air flow at intended flow rates and count the drips over time. Sorry to be a downer but the regulators are likely so old that the diaphragms and seals are shot. does not hurt to pressurize them and see if they work.
For paint you need a regulator and a coalescing filter feeding to a desiccant filter. Clean dry air is a 100% must for modern paints.
K
Kirbot
New Jersey
I think I have what I need now.
Picked this one up at an auction too.
I don't think it has ever been use.
Hopefully it will be effective enough along with an inline filter at the gun.
larry_g
oregon
That is a particulate filter, not for water removal.
lg
no neat sig line
K
Kirbot
New Jersey
lg
no neat sig line
Not according to the label on the box.
It says "for use in general applications where effective filtration and water removal are required."
