TireTracks
I decided to make a thread that I can post the progress of my toolbox i'm building.
It's going to be 48" wide, 24" deep and 36" high. It's going to have 11 drawers. IN 2 banks, one roughly 12" wide and another about 24-25" wide.
I'm starting the build at home, and once I run out of things I have the material to build at home, it's going to get moved to my HS woodshop so I can finish it in class.
On the 2 most used drawers I have some real sliders to use. the rest will get hardwood sliders. ( we have a old cabinate full of steel chunks and lathe parts that works fine with no sliders and is made of softwood. So they will be fine for me)
Depending on how much time I have after the drawers are built and installed. It's going to get a 3/4" plywood or 3/4" butcher block top.
It's not going to perfect. But It's going to be cheap to build compaired to a storebought one. I'm a function over form kinda guy.
The plans.
After 2 afternoons of work- I cut the joints on a tablesaw, then cleaned them out with a wood chisel. if the weather is warmer this weekend i'm going to glue the joints. But it's too cold right now.
The plans.
