New 13,900 BTU electric heater
5lima30
Mountains of Western NC
About a month ago I picked up a portable electric construction heater from Northern Tool. It is 13,900 BTU and 4000 watts. Finally got my garage electric hooked up and wired. I went out to the garage this morning it was 35F within an hour it raised the temp to 64F! I should note that the garage is 16x 28 and not insulated yet, although it does have Tyvek under the siding. I made mine a wall mount unit by utilizing an old wall TV mount that pivots so that you can aim it. Overall I am pleased with the unit. The only negative is the fan has only one speed and is a bit noisy:(. I will try to get a pic posted later.
Boyd Who
Manitoba
Those little heaters really work well! I have a 4800 watt unit heating my new shop and I love it.
Hurry up with your pics...I'd like to see how you adapted the TV mount to work. :thumbup:
jvitez
Big Sky Country, Canada
I used one of these in my old garage. Worked very well.
But please be careful! The sides and top of heater can get very hot, and a melting ratchet strap sounds like a beautiful fire starter :shocking:
It might be fine, but run it for a while and check to make sure. In any case, congrats, and enjoy some heat!
Boyd Who
Manitoba
Slick idea using the TV mount. I agree with jvitez though...you'll want to strap it down with something that won't melt or burn, the cases do get quite hot. Right now mine sits on top of a metal cabinet.
rickairmedic
louisville ,Ky
Looks just like my Dayton 3VU36 . I have been using it a couple years now in my 20X23 2 car and it does a great job of keeping it warm out here .
Rick
5lima30
Thanks for the concern, I plan on using some metal clips and small sheet metal screws to fasten the base to the TV mount. BTW those mounts are surprisingly sturdy! Now I need to figure out a use for the other identical TV mount LOL!
PassnThru
Bowling Green KY
Well, obviously that would be where you would put the air conditioner :lol_hitti
