Remote central looking on my toolbox
hultarp
Sweden
Remote central locking on my toolbox
This is my little remote control project, that did get a little out of control ;)
Just a short story about me, I’m living in Sweden for the moment working as a electrician. I´m a graduated aircraft technician and are going to move over to work in Illinois in usa. I have just 1 to 2 month left until I get my visa.
It started with a small idea when I did get my Snap-On kra4820 on the side of my Tengtools rollcabin. I though it would be to disturbing to have several keys to handle every single day, so I started to sketch on a central looking solution to my rollcabin.
I did buy 3 central locking motors from a saab 9000
They didn’t work the way I had expected, so I did rebuild them a little bit.
Originally they did just pop out with a fast snap and then they was in a neutral position again. But after some thinking I did rebuild them to have 2 dead ends with 4 pounds of torque.
Unfortunately the looking bar where to heavy for be hold by the motor in the “open” position without falling down, so what should I do?
Back to AutoCAD again, I started to think about over bending in landing gears on airplanes. So I did sketch up a blueprint over a mechanism with this technic.
It did work superb on the tengtools rollcabin, the problem was the Snap-On cabin because it´s just 20 mm between the back and the drawers and the motors are about 24 mm wide.
I did find out that I couldn’t maneuver the looking bar in the same way as the rollcabin, so I did pick out the grinder and did a hole for a strut as shown in the picture
I did also grind a hole for the motor and the brackets in the floor.
When all that was working I figure out that with a little bit of cupper pipe in the end of the bracket against the strut it worked allot better.
Movie on the final Snap-On look
www.hultarp.se/teng/snapon.m4v
The side cabin did also get it´s own look ☺
I will ad more pictures later on
Now to the funnier parts.
First I started out with a small electronic box, all the wiring and remote control electronic went down into that box.
Wiring diagram over all the box, www.hultarp.se/teng/wiringdiagram.zip
The parts I used for this:
Remote from Velleman VM130
2 alternating relays with dual contacts
1 Case/Box
12v battery on 7.2Ah
As you see in this picture and in the diagram I connect the wires from the motors into one socket and 12v into another so I have a total of 8 cables in to the case.
I did also place a switch to main power from the battery so I could turn it of on weekends and holidays.
This electronic box did I place in the big electronic compartment in the bottom of the rollcabin, as you can see I did build a framework to hold the Plexiglas in place and to get a nice looking electronic box.
When I did this I got a small idea that it maybe could be smart to have 110v on the cabin when you use some instruments or just want some more lights.
Products I did order for get this to work:
3 us sockets for panel mounting
2 automatic fuses each on 10 amps
1 relay Primary: 12v Secondary 110v (this was a stupid decision because why should I use my 12v power when I don’t use the 110v system. If I had done this today I had got a relay primary 110v secondary 110v)
1 Switch for the relay
It was a little tricky to get the sockets lined up but I did pretty good I believe.
One more think I did wrong was to place 10 amps fuses, I live in Sweden for the moment and we use 230v so 10 amp are in 110v systems 20 amps. I did use 2.5 mm 2 cables so I don’t think this will work when I connect it to power. But who knows?
The electric compartment did I build with the usual things we use when we build electronic boxes at work. I share a short list:
DIN-rail for the fuses and ground terminal
Cable channels
Plexiglas
Stuff I have left to do/or improve:
• Connect the ground wires to ground on some good place
• Build a metal bracket for the battery
• Build a metal case for the motor on the snapon cabin so you don’t can open it from the outside.
• Find a way to get 110v into the box, I don’t know if there are male us sockets for panel mount? You maybe know?
• I want a clock in the front of the toolbox, panel mounted but I cant find a clock to fit in a panel.
The place I did left empty in the electronic compartment is for the components to my next project.
Fully remote controlled toolbox, with bigger wheels and a slightly raised work height.
Hope you liked my project
Techniker
ABSOLUTELY BRILLIANT. I've been meaning to check out the locking mechanism on my toolbox more closely and this gives me the excuse to do so. I wish I had seen this before I filled my box with tools; would have been a lot easier.
rsanter
visalia ca
nice
now all you have to do is scare up the parts for a proximity key that will automatically unlock the box when you get close to it and lock it when you walk away
bob
Busted Bolts
NewEngland
Thats F#!$%ing AWSOME. When its all done you should present to SO and get royalties for your invention. Thos could be an upgrade for boxes in high theft areas. Nice job and welcome to the forum
honcho
Near Sodom & Gommorah (aka Wash. DC)
Great job! Now all we need is the voice command Toolbot" helper by "Snap-to-It" When you're upside down with your head under the dash and you need the one tool you didn't bring with you. All you do is say "Toolbot, bring me the 5.5mm deep socket. It's advanced algorithm will go to your toolbox, scan the drawer where the socket is supposed to be and not find it there..... Next it will open each drawer one by one and scan until it finds the tool. If it finds the tool, it brings it to you and it's articulated arm will gently hand it to you. If it does not find the tool it will trundle down to harbor freight and buy another one. The Deluxe version will then bring you a beer. Sort of an advanced version of Bender from Futurama. When you're about to do something stupid it will wave its arms and yell "Danger, Danger, Danger" like robot from "Lost in Space"
larry_g
oregon
H
hultarp
Sweden
Re: Remote central locking on my toolbox
nice
bob
I have thought about it, but can´t find the stuff to do it. But it would be waaaaayyyy cool to have it. If some one have any clue, post a replay please :)
Thank you busted bolts, I think you guys like it better for free ;) So feel free to follow me into the world of remote locking haha
That would be the invention of this century, I will start sketching on it ;) hahha
Are you looking for an IEC style connector? http://www.newark.com/schurter/4300-0704/connector-iec-power-entry-plug/dp/50F2839
This style should be avaiable around the world. Nice looking install. Do you have a manual way in if all the electricals fail?
lg
no neat sig line
Thank you, I couldn't find that sort of socket anywhere. Will do some more calls tomorrow now when I know the number and the manufacture. :)
I have not done any changes on the locks, so I can use my keys if I want. But if I cant find them I can drill a 5 mm hole in the top and "fish" for the locking bracket ;)
H
hultarp
Sweden
By the way, can some moderater change the thread tittle to locking? I cant figure out how to do. Thanks in advance :)
H
hultarp
Sweden
Here are some more pictures of the side cabin, I will make a movie but I didn't have time today :(
Here are my next project, remote controlled toolbox. This is just a prototype :)
And I did paint the drawer covers black to match my tengtools rollcabin.
H
hultarp
Sweden
I will post a youtube link tomorrow, with 720p quality so you maybe can see something more than pixels ;)
scott37300
Wisconsin
Nice engineering!!! :bowdown:
Couple questions. Is that just a car key fob that you use for the lock/unlock? If so what kind of receiver do you have that picks up the remote signal? How do you recharge your 12 volt system, do you have a small trickle charger plugged into your AC electricity to keep your 12 volt battery charged? I've installed a couple of remote starters and power lock kits for car alarms but they were all kits and just had to put them together.
I think the proxy sensor would be great so it would lock/unlock everytime you were by the box and you wouldn't have to press any buttons.
H
hultarp
Sweden
Svenskarna kan!
Gotta give a couple of thumbs up. :thumbup::thumbup:
Tackar, ni norrmän är inte långt efter ;) haha
Very nice!
That Tengtools box looks really nice too. I had never looked at those.
They are just sold in Europe, I dont think you can find them in the USA. But they are superb quality.
Its a kit from a electronics shop here in Sweden, just a box that you connect the motors and 12v dc. Its for aftermarket car installation but works just fine for toolboxes ;) I dont have any solution for the charging jet, because we have 230 AC and I cant find 110 AC chargers here in Sweden. I will mount a charge level indicator to the battery and a charger so when I connect AC voltage to the toolbox it charge the battery if I want it to. I hope I did answer all you questions :)
mdbeck1
Norman, OK
Very cool, you didn't set it up so the drawers slide in/out? Just kidding.
It should just take a couple of small stepper motors (with some light cable/string) with switches placed to cut the power when the drawers are all the way back.... When the signal is received from the fob it closes a circuit. You should be able to tap into the same power to run the stepper motors.
Take a look at the "do nothing" box that was posted the other day for some ideas.
