Removing tape residue from tool box
Borrego
San Fernando Valley
Recently picked up a 40" Craftsman top box and began cleaning it up today. Previous owner had placed masking tape on the front of the dawers to identify tools inside each drawer. Tape had been there so long it had turned yellow. Removing the tape left a residue I am having a difficult trying to take off without tearing the paint up.
Anyone with suggestions on how to get the residue off?
Ritter4.0
Maryland
I've had pretty good luck with Simple Green. It takes a while and some good scrubbing, but doesn't mess with the paint at all.
Another good one is Purple Power, but don't use it full strength, and be sure to wash it all off because I think it can mess with paint after a while.
hofferwood
DownRiver Michigan
Zippo lighter fluid.
NO don't light it!!!!!
Seriously, it takes the gummy crud right off. A little on a paper towel.
But try it on the inside of the drawer to see if it bothers the paint.
Chuck
usdemt
South Dakota
Xylol, available at most hardware stores works very well. But as with all chemicals test it on an incospicous area first to make sure it wont damage the paint.
pfbz
My go-to adhesive remover is Goof-off (which is basically Xylene and Ethylbenzene)
Tool Pants
San Jose CA
Don't use brake cleaner. I tried it on my old Craftsman and it took the paint off. I think it has acetone in it.
shanker
Portland, TX
all the pro's on here and nobody told him to use the right tool for the job.
What you need is a 3M eraser wheel, it'll clean all the gunk right off and leave your finish completely unharmed
Dont use too much pressure, its not the force that makes that thing work
Daddy_Rabbit
the guy does NOT need a $20 eraser wheel to remove 5 cents worth of tape ... lighter fluid or wd-40 will work. and cheaper.
