george4
Need to pick up wobble extensions in all drives. I see SO has wobble and wobble plus, what is the difference? SKs and Craftman look good too, any input?
I prefer separate wobbles as opposed to the wobble plus. They do work fine as a wobble extension (snap ons) but I wouldn't rely on them as a "solid" extension.
I've only broke one extension ever, that was a Matco 1/2" drive 1 1/2" chrome one. Using a 24" breaker bar (not an impact!) to remove a crank pulley bolt.
I do prefer the feel of the snap on's opposed to my matcos though and it's a world above regular c'mans.
You can feel the difference between a Snap On extension and a Craftsman extension ...![]()
I have never had good luck with a wobble extension. I just never liked them. IMHO if you can't reach it with a straight extension then you need a universal socket.
I love mine.
Sometimes you can get away with a universal joint and a standard socket, but I have found in many cases there just isn't enough room.
As for extensions, I have broken everything under the sun with the exception of a snap on extension. The snap on units are thinner, stronger, have less “wobble” (I know, you want wobble on a wobble extension and that they have), and the knurling is a nice touch. Try out several brands if you can, and pick the one that supports YOUR needs. Good luck, and keep us up to date on what you choose.
I have never had good luck with a wobble extension. I just never liked them. ...
I love mine.
How the hell do you break extensions? I have broken a few sockets through the years as well as a few ratchets but the closest I ever came to breaking an extension was when I have broken a drive reducing adapter. Don't you know when it's time to go a different direction before breaking up your tools, regardless of getting replacements for nothing I think a guy has to know when it is time to get a different plan of attack!![]()
i am agree with you! but i had snap on wobble set as i only need to make little degree off instead pissed off on univeral joint because it flex down and i cant get it stright unless i had to tape it with electrical tape...![]()
You must not work on cars for a living.
What does one have to do with the other? Are you saying auto techs are stronger than they are smart? If so, I think some folks here might take offense to that.![]()
Cause I'm dumber than a sack of hammers and I've never had a problem telling the difference between a 3/8" drive job and a 3/4" drive job.![]()
I do not understand that. If you need the wobble to break loose a nut, why would the stress be any less than if you had a straight shot with a regular extension?
Just buy the Snap On ... everyone knows it better ... it has to be, it cost more.
How the hell do you break extensions? I have broken a few sockets through the years as well as a few ratchets but the closest I ever came to breaking an extension was when...
That's pretty straightforward. The guy has apparently never broken an extension, which likely means he doesn't do this stuff for a living. Here's how King and I both jumped to that conclusion:You must not work on cars for a living.
