120V-only Subpanel
Mattlt
MN
Another thread mentioned a 120V-only subpanel. I thought if you ran a subpanel you needed to run 240V to it? Is a different kind of panel required, or is it all in the wiring?
I'm thinking of building a small shed and I'd like to have a couple of 120V circuits in it... 240 would be overkill in this situation.
I know 240 would be the ideal solution, but can someone school me on the 120V subpanels?
acer66
Western North Carolina
If you have only one phase coming in it you would have a 120V panel,
meaning both bus bars at the Sub panel are on the same phase.
You could make any 120/240V panel I ever saw a 120V only panel
via wiring but I do not know how legal that is.
Norcal
The nomenclature "phase" is incorrect when one is refering to a single phase(1Ø) source, "leg" is a more correct choice since 3Ø power is rare in residentail in the US & 2Ø power is a obsolete power system.
mrb
how much power are you running to your shed? do you just want one (or two) circuits for lights and general use receptacles? if so you dont need a subpanel, just run 12/3 UF (or 10/3 or possibly larger depending on distance involved), or conduit in wire, and supply it with a 2P 20a breaker and youre complying with the one circuit rule that lets you not have a subpanel. not sure if a disconnect is required, i dont think so but if it is you can use a 20a 2P snap switch (toggle switch ie light switch)
Mattlt
MN
That's a good idea. That sounds about like what I want to do.
Berserker
WI
You can put for circuits in subpanel without a disconnect. You could just run 10-2 and put in a couple 15 amp breakers. For a shed, you may just run 10-2 for distance, and one breaker.
I am not sure what the code is, I haven't done it. But if you only run one hot out there and have a subpanel set up for 220, you could do a jumper between the incoming lugs.
Size up on wire for every 100 feet, for voltage drop is a good rule of thumb.
Buzzy
Wouldn't you need to run a Ground fault circit breaker as well?? I would think so because you are running a wire outside.
mrb
no. 15 and 20 amp 120v receptacles must be gfci protected when outside or in a garage, but that doesnt mean you have to have a gfci breaker. You can use gfci receptacles, (or have one gfci receptacle supplying other standard receptacles from its load terminals)
