What is this tool?
JayL
Manila, Philippines
Can you please help identify this Heyco tool and what it is used for.
Thanks
mrholeshot
MEMBER EMERITUS
Piston ring expander. Allows you to open up the ring to slide over the piston
scott37300
Wisconsin
Can somebody please describe a bit more in detail how the tool is used.
Thanks
There isn't much more to explain from what mrholeshot said. It will open a piston ring enough to slide over the piston and into the grove without breaking the ring.
airbuff101
Jay,
The ring is mounted on the tool then expanded and slipped over piston. Then ring is slipped off and into groove. Rings tend to twist if simply expanded at opening and not supported by a tool like this.
It is a common old design that probably originated in the U.S. as they were quite popular here under many brand names.
airbuff
rsanter
visalia ca
piston ring expander for installing piston rings
most of us 'spiral' the rings on but some rings can actuallt be damaged by doing it that way or you can 'scratch' the piston
close the tool, put the ring on it
squeese the tool to expand and put over the piston
slide ring off tool and into the piston ring
bob
Monte
Germany
common tool over here. Still offered by Gedore, Hazet, Stahlwille, Gedore, Heyco, Elora....
Mr.Nutcase
USA
That is for measuring someone head size, LOL,
it looks like piston tool like the other has said
J
JayL
Manila, Philippines
How about these tools below . What are these?
1. Dako
2. Snap On
Are these part of a puller kit? I cant' seem to find the part numbers on the SO site anymore. The handle is A14-1.
Thanks
daveroy
Omaha NE
Nut-case... that first one looks like a tubing expander to me.
Second one some kind of seal driver set.
(just guessing)
