Show off your "Custom Handled Ratchet"
nissan_crawler
Wichita, KS
not sure if this one counts, but...
rocklobster
Are there any brands of chrome handle ratchets that you can remove the handle on? I thought I saw a post of someone removing a chrome snap on handle...
rocklobster
Well this thread inspired me today to replace the handle on my Husky Pro ratchet.
I love this ratchet it is so handy, but I really dislike soft grips, so my only gripe with the ratchet is the handle.
prAy4kZgbjTxJW6t_SmL5A
A year or two ago I found a plastic handle vintage phillips screw driver rusted beyond use in the dirt, I usually keep stuff like this so I tossed it into a drawer in my shop knowing that I would 'need' it someday...
DbzdDTh9bBBGmWGb6tK0KA
I like what it says on the handle too:
QAIvLceFGYvdy85IgPacOQ
ORk_IwBxffu5NAzANL8_zg
In haste I got a couple of vise marks on the handle, no worries the handle has it's share of nicks, next time I will pad the jaws.
Kirbot
New Jersey
My "custom" ratchet handle is about 1/4 roll of electrical tape.
I couldn't stand the knurling on my 1/4" SK, so I added that to pad it some.
rocklobster
With all the interesting handled ratchets poping up lately it was mention that a thread was needed to showcase them all in one place.
You might see some real bastardizations in here so beware.
I'll start with a few I did.
Fuller/Gray Canada
This Fuller/Gray is boss!
I love fuller screwdrivers and gray ratchets. Was the gray ratchet originally equipped with a chrome handle?
G
Gtamazing
Fort Erie On.
yeah it just had the regular tapered shape chrome handle. you could really tell the hardness of the steel on the outside compared to the softer interior when I cut it down.
mrholeshot
MEMBER EMERITUS
Here is one I did this morning. Harbor Freight 1/2 ratchet cut down and Harley steel shift peg. drilled peg .015 undersize. Heated shifter peg in the oven for 35 min at 250 degrees and put ratchet in the freezer for 2 hours. Tapped the peg on and let it cool. Now I have a 1/2 stubby. What do you think.
PT Doc
Very nice work. How many teeth on that one?
Case IH
Green Bay WI
How much would it cost for you to make one of those to sell?
mrholeshot
MEMBER EMERITUS
I'll have to see if I can find another steel harley shift peg. Most of them are aluminum and this is one I had off my Ultra. I'll check around and see if I can find a few. The ratchet was a whole 10 dollars.
G
Gtamazing
Fort Erie On.
If I wanted to put one of these
On one of these
What would be the best sized handle for the 1/2" ratchet. I'm thinking #4 Philips
digdug18
Danville, PA
Are you guys just going for a pressed on fit, or are you using epoxy or something to make sure the don't come off? Also how are you getting the screw driver handle off the screw driver shaft? Are you heating it up first and puling it out, or just pulling it out or what?
Andrew
Catalyze
New Mexico
This is a great thread for creativity! Now it makes me want to go out and change something in the ratchet drawer.....must fight the urge.
Craig
JeremyManning
Ontario, Canada
I pulled mine out using a vise and 2 prybars not heat and I used some jb weld in the hole to ensure it doesn't come apart, there is a thread that cross references snap on screwdriver handle and matches to ratchet sizes that is what I used as a guide for determining which size screwdriver to get
ovilla
Plainfield, IL
Craig
That's what Harbor Freight is for. Go buy some cheap tools and give it a try on those first. Then play with your good stuff after that.
gj67stang
Sycamore, OH
Is it possible to put one of the new comfort grips on a sx80a? I can't find a ~17"+ long 1/2" drive locking flex with comfort grip. sx80a is the only locking flex in 1/2" that I see.
http://buy1.snapon.com/catalog/item...=22911&supersede=&store=snapon-store&tool=all
It could be done. The end of the ratchet handle would need to be turned down to fit a soft grip.
Andrew
The ratchets I make just use a press fit to retain the handles - this way, they can be removed for whatever reason.
Kirbot
New Jersey
Here's another one.
I didn't bother turning the handle down, I just drilled an undersized "stepped" hole, with two diameters.
Then used a dead blow and hammered it on.
I've been wanting a comfort grip 3/8" ratchet for a while!
The handle is from a Harborfreight screwdriver.
Pro-Painter
Winston-Salem, NC
Here's another one.
I would like to do something like that except I plan to use a Duralast screwdriver handle. Hmm...
powertrip
Columbus Ohio
Here's another one.
Can you explain how you did the step drill method?
Kirbot
New Jersey
Sure
It's pretty simple really.
The duralast handle is shaped just like a Snap On handle.
(picture stolen from mrholeshot)
Drill a deep hole the diameter of the single ring of knurling, and then drill a shallower hole a little smaller than the diameter of the double ring of knurling so that the ratchet can get pressed in.
I made the holes very undersized and then just hammered it together.
It seems fairly secure, but if if comes apart I'll just add some epoxy.
powertrip
Columbus Ohio
Sure
thanks
Gmonkee
Just go out and pick up a cheap but usable ratchet and a beat up screwdriver or two at a swap meet or junk shop, whatever is in your area. Practice modding on these gems a few times until you have a plan on how to do it smoothly.
Then carefully choose a handle that compliments your nicer branded ratchet for size and form and build your dream ratchet.
I used a cheap GN 1/4" RH and my fave Stanley 60 series handles to create and recreate a few pieces. Someday I may get around to making my RH 3/8" drive flex head with long handle and a nice hard handle. Still trying to find two key parts yet.
G
Gtamazing
Fort Erie On.
Two Mastercraft ratchets, 1/4" with a Wera and a 3/8" with an Xcelite. These are the first 2 I did. both were drilled by hand in a similar step method to accomadate the handle shape.
rocklobster
Very Nice Gtamazing!
I have the same mastercraft ratchets, I think that I need to go find some screwdrivers to butcher!!!!
oh and Gtamazing I found that soaking those ratchets in some auto trans oil and some breaking in really smoothed them out.
Sterff
PA
Here is my Gearwrench Snap-on hybrid I made a few months ago.
SMKS
USA, planet Earth
Here's one I just made up. I just bought two cheap used import ratchets and decent used screwdrivers to mock up some ratchets. I bought cheap stuff in case I screwed something up.
This is a Taiwan ratchet that I paid $5 for. It has no brand name, but is a Facom copy with a very smooth action that seems to work well. It had a trashed rubber handle. The new handle started as a $1 Xcelite nut driver. I drilled out the handle and pounded it on with a rubber mallet.
The hardest part is lining up the script on the handle with the script on the ratchet. I did another cheap ratchet/handle combination and the script ended up off center.
DonkDonk
Norman, OK
I just did a couple today. The FH80 I got from Jaysonb here on the GJ. On the FHNF100 3/8 roto I used a SPB8A pry bar handle and the THNF72 1/4 roto I used a SDD146 screwdriver handle.
