The old Craftsman is about played out
I dont own this particular one, mine says matco. However, it is the best close quarters cutter you could ask for.
http://www.tooltopia.com/robinair-42071.aspx
Rothenberger Minicut I Pro
If not, maybe Elroy might enjoy one of these;
http://www.alibaba.com/showroom/mini--tube-cutter.html
Elroy likes the notched rollers. We'll give that one a look see.
I have a Ridgid that I really like. Made in the USA and sold at Home Depot.
Elroy is seeking your recommendations on a tube cutter for use in restricted access applications. 1/8" to 1/2" range.
The Ridgid however is a viable choice but we note Ridgid specifically recommends against using them with stainless. That tells Elroy the wheel geometry and hardness may not exactly be what we're looking for.
You must know that the notches allow a cut much closer to a flared end.
That smaller RIDGID is at least 2x the size of the Rothenberger Minicut.
Stainless steel cutting is not mentioned in your original inquiry.
Well ya. The last time I checked I came away with the distinct impression that Elroy wasn't a complete dumb ***. A ***** maybe, but no dumb ***![]()
Mild steel capability would be a must. Stainless capability would be nice but it's not a deal breaker
I have not yet used a tubing cutter that won't cut mild steel- it wears out the cutters faster.
Stainless is a different animal.
My suggestion would be to find stainless a cutter wheel and see what size tubing cutter works with it.
Here are some pics of the Roth Mini next to the Ridgid close quarters cutter.
Which model Ridgid is that?
model 101
Dont know the COO on this one Malco is a US company in Minn.
http://www.toolbarn.com/malco-rtc623.html?ref=base
I've been using an Imperial TC 1050 for awhile. I don't know offhand who sells them new, as I have been finding mine a swap meets.
jerry
When Elroy needs cutter for STAINLESS, Elroy NEED to mention STAINLESS.
http://www.smallparts.com/dp/B002WS...-20&hvadid=12879423679&ref=pd_sl_2ijbppl9zq_b
http://www.mccusainc.com/Tools/Tubing-Cutter-BearingInstalled.htm
Excellent suggestion that lead Elroy to Reed Manufacturing:
http://www.reedmfgco.com/index.html?screen=mini_tubing_cutters
Elroy have you looked at the HT Mould #RC375 ratcheting tubing cutter.
