Above 1200 Sq/FT Bald is Beautiful - 7k sq feet+ of Gruntledness
T
tig
Durango, CO
Awesome build! So is this near Lake Sammamish? The reason I ask is, I have bean spending the last 4 1/2 months working on the build of the new Swedish Hospital up on the hill in Issaquah. And not a day goes by where I catch myself in a window enjoying the view of the lake and the surrounding mountains. :lol:
We are truly blessed in the NW :thumbup:
Yep, it's Lake Sammamish. I can see Swedish from the house...
:rocker:
ssleepingbeauty
Washington
Cool. It's going to be the fastest built hospital in the country. From the ground up. The main office building and the ER will be done June 1st and the hospital completion deadline just got bumped from November to July for completion. While still maintaining quality in craftsmanship and materials. It will be nice when complete.
xcgates
TX
So, getting much beauty sleep these days?:)
T
tig
Durango, CO
Some more pics.
Slow Gray Mule
MS Gulf Coast
Here's the auto-drain.
And the plumbing to the 60 gal tank and my air regulator/filter:
I looked over the two threads, this one and the seperate compressor thread. Nice set up. I have a question though, what is the braided line you used for the auto drain and the line from the 40 gal tank to the 60 gal tank? I don't recall seeing it mentioned in the threads. Nice garage, btw.
T
tig
Durango, CO
I'm not sure what you are asking. I have one auto-drain for both tanks. A braided line goes from the drain on the 60 gal tank to a tee on the 40 gal tank, from there it goes to the auto-drain.
Are you asking what kind of line this is?
It's stainless braided line. Totally overkill, but the guy I had helping me did it before I could say "whoa!".
Slow Gray Mule
MS Gulf Coast
Yeah I was wanting to know what the line itself is made from. I like the look of the braided line. I'm looking to plumb my garage and may use the braided ss to run from thr tank to the hard line.
go_n_low88
Very Nice Garage. When you swapped your lift over to 220v from 110v did you notice a difference? I am in the same situation where I can choose the 110V or 220V motor.
T
tig
Durango, CO
If there's a difference it's minor. I thought I'd see a perceptible increase in lift speed, but I don't think I do.
T
tig
Durango, CO
If you haven't been following my thread on using a Bend-Pak RJ-45 sliding bridge jack on my Backyard Buddy lift here's an update.
Short summary: The RJ-45 mostly works on a Backyard Buddy lift, but not optimally. It sits too high (about 1") and has rollers designed for a track, not the flat rail the Backyard Buddy lift has. Jeff, the VP of Marketing at Bend-Pak reached out to me to use me as a guinea pig for developing modified outriggers for the RJ-45 that will adapt it to work perfectly with the BYB (more details and pictures in that thread here).
Today these showed up at my house:
I installed them on my RJ-45 and THEY WORK GREAT!!!
Good shot showing how the outriggers now sit on the rails:
The flat rollers are perfect!
And what's the point of a jack if you don't jack something up with it:
I have become a huge fan of Bend-Pak!
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I was looking at the pics and noticed that the left leg or back leg looks like it is cocked in at the top. Is it or is it just the way the camera lens makes it look?
ct71rr
Massachusetts
Very nice place you have and those cabinets are awesome. I'm not trying to be a smart **** but, why would you need to jack up a car that's on a lift?
T
tig
Durango, CO
That's an optical illusion caused by the lens. In fact, just last night I verified that the lift is level side to side and that the posts are vertical under load...
littletoes
NE Washington
The braided lines also help absorb vibration off the tanks, although I'm thinking one of the tanks is just used for storage?? I think....
Love the red and black cabinets! Are they steel, or wood?? Cant tell, but the drawers, if wood, I've never seen them that thin!
Either way, NICE!
Love the lift too.
Wish I could keep my shop that clean! ;)
Jack Olsen
Los Angeles
Tig, that looks like a great set up -- the best of a four-post's parking options with the ability to also do quick brake pad changes.
T
tig
Durango, CO
Either way, NICE!
Love the lift too.
The cabinets are by Baldhead Cabinets and are steel (http://www.baldheadcabinets.com/custom_series.html). This thread is named "Bald is beautiful" (partly) because of them.
Look back a few pages and you'll see it is not normally this clean. Give me a few weeks and you wont even be able to see the floor! :)
T
tig
Durango, CO
Jack, I'm still not convinced in the merits of a 4 post lift. I currently have no need to park another rig and after using the 4 post lift for a bit, can see the disadvantages: Takes tons of room & is generally in the way and requires a bridge jack like the RJ-45 to be able to do wheel-off work.
I think if I had to do it all over again I would go with a scissor lift like system similar to the one you linked to off of your thread (with two scissor lifts embedded in the ground in parallel).
But, in the end, I'm not complaining at all. I'm motivated to do much of what I do so that I can learn. And learn a lot about lifts I have :).
Kevin54
MEMBER EMERITUS
Urbana, Ohio
As stated, brake jobs, pull a tire, swap rearend gears (you have to pull you axles), endless possibilities. Basically the same things you do on the ground but you can stand up to do it.
ct71rr
Massachusetts
Yup, don't know what I was thinking (or wasn't thinking)...should have been obvious :tard: Thanks for the info. That in-ground two post/platform lift is pretty cool!
787B
Baltimore, MD
Scissors and not two-post, tig? A MaxJax?
Yeah, tig, I think you could sell that 4-post for a big profit and use that to fully-fund a MaxJax if you really want maximum space, or mostly-fund a twin-post of your choice. The in-ground scissors are nice but nothing matches the freedom of a two-post.
Me, I make do with a second-hand scissor jack and lumber ramps... :beer:
T
tig
Durango, CO
This weekend I replaced the water pump on the FJ40. As with everything like this, for me, it's learn as I go. Someone who knew what they were doing probably could have done it in 1/4 the time. But in the end, I got it done and it's working great.
Evidence of the leak:
New pump:
The mess in progress:
T
tig
Durango, CO
Last week I got my diamond plate floor panels back from the powder coater. As you'll recall I originally planned on a 2 post lift and had forms counter sunk in the floor for a circa 2002 Bend Pak lift. Later I decided that I put the forms too far forward and I wanted a 4 post lift anyway.
So I filled the forms with concrete. I didn't want to try to match the epoxy floor so I came up with the hair brained idea of having some diamond plate steel panels made to fit.
I had them laser cut based on a cardboard form I made. I used washers and tin scrap to ensure they were flush with the floor. They are held in place with silicon and the edges are sealed to prevent fluids from getting underneath with silicon as well.
Here they are installed. I think it looks hawt. Definitely a conversation starter. :lol_hitti
Jack Olsen
Los Angeles
Well, you could make it look 'on purpose.' Call it the 'Wide H Garage' or 'The Dumbbell Palace.' Add some more examples around the rest of the shop.
Something like that. :)
Seriously, though. It looks good.
T
tig
Durango, CO
I figured you all may appreciate this...
I recently decided I needed a 3” orbital polisher to compliment my Flex 3401 6” Random Orbital polisher that I’ve used for years when polishing the finish on cars. I couldn’t decide whether to get the Griot’s 3” Random Orbital (which is electric) or the Griot’s 3” Pneumatic Orbital (which is air powered). So I ordered both. Griot’s fantastic customer service and return policy made this decision easy.
This post provides a comparison of the two polishers…
I love driving my cars, but I almost love keeping them looking new more. If you’ve ever seen my 1988 Porsche 911 Carrera in person you’ll know that photos like the one below, while great, do not show how great the paint looks after almost 23 years justice.
A few weeks ago a friend of mine fell into a 1989 325xi with 149K miles on it. It had been sitting for 3 years after encountering some sort of electrical gremlin. He bought it for $1000.
I took the following pictures the day he got it to another friend’s shop to see how bad it was mechanically (it wasn’t bad at all; he spent about $600 getting it 100% roadworthy including new tires; I drove it and it drives like new!).
Over two days we took my Flex 3401 and went at it. I started with an orange pad using Menzerna SuperGloss followed by Menzerna PO85Rd, followed by One Grand Blitz Wax.
The roof after cleaning, but before polishing
This door's not done yet:
The bonnet was has the best paint on the car. It came out extremely well!
The 525xi has a lot of “tight curves” that the 6” pad on my Flex polisher simply can’t reach. Hence why I decided I had to have a 3” polisher.
Griot’s shipped both out to me and I gave them a quick test on the paint on my 4-post lift in my garage. Here are my conclusions:
I did a quick test on the powder coating of my 4 post lift and my conclusions are as follows:
Griot's Professional 3" Random Orbital - $94.99
Summary: Way too big and heavy for what it does. And what it does, it does poorly. The lightest of pressure while polishing causes the "clutch" to reduce rotational torque, stopping the pad from spinning. The only way to keep any RPMs up is to BARELY touch the surface of whatever you are polishing.
Griot's 3" Pneumatic Orbital - $79.99
Summary: Works great! Much, much smaller, lighter, and cuter than the their electric 3" random orbital.
I did not find the Pneumatic too loud at all. It makes a nice whine sound a bit like a dentist’s drill. I suppose after several hours of using it would get tiring, but that’s true of electric tools as well.
After spending about the same amount of time polishing a face of one of the posts of my red lift the electric 3″ Random Orbital shows no pickup of oxidation and even still shows polish! The 3″ Pneumatic, however, shows an expected amount of oxidation. The finish of the post also is clearly actually polished where I used the Pneumatic. The finish where I used the electric is just clean.
You’ll need a good air compressor to run an pneumatic polisher. The Griot’s documentation says at least 4 CFM @ 90PSI, but I suspect you’ll only really want to go this route if your compressor puts out 8-10 CFM @ 90 PSI.
Here you can see just how tiny the 3" Pneumatic Orbital is in my hand. Compare that to the last photo showing the electric model.
The big, fat, slow, and weak electric (can you tell I've made my mind up?):
On Edge
Cincinnati, OH
What a transformation you did on that BMW. Your garage is still one of my favorites. I would image that it is a joy every time you go out there to work on something. Keep the pictures coming!
