mpr455
My question is which is better? Also i've been told that you can achieve r-20 with foam. Can you do this with fiberglass? Without breaking the bank? Hopefully somebody that has gone through this can answer.
I do have one gripe about all the energy saver pitches: All the products pitch that you can save you "up to" X amount in energy costs. WTF is "up-to"??? That is such a cop-out. Although I really want to be energy conserving, it really pisses me off. Basically none of the claims can be trusted.
I've got sprayed-in-place foam. It is more expensive. At the time I was building my house (3 years ago), I priced both and the foam was twice the standard bat in the wall with blown in the ceiling. I decided on an "envelope" jobDon't know what your codes are, but our codes dictacte the same envelope, it's done with a 6mil vapour barrier, all cracks, joints and poly-to-poly is sealed with acoustical sealant, electricl boxes are installed with poly pans which are pulled through the 6mil and taped or secured and caulked to the 6mil.. They sprayed the walls (6" studs) and under the roof (6" & 8" rafters). This made the attic area stay warm from the heat that passed through the ceiling and light fixtures, etc. in the ceiling. For example when it was in the single digits last winter, the attic was still a respectable 60-65. But for me, the one thing that foam does that conventional insulation job doesn't do is seal all the cracks to the outsideHow do you figure? again, our codes dictate all gaps and cracks are to be sealed or if its a gap, it's stuffed with insulation or we carry canned foam for such cases, all gaps and cracks are still sealed off by the 6mil vapour barrier. I know you could wrap your house with house-wrap and caulk everything you could find, but you still won't seal it up like a complete envelope of foamHow so? Batts nor Foam go behind or infront of the outside wall studs to create a thermal break, the only way to stop that cold trasfer would be to do an exterior foam wrap or horizontal framing over the outside wall, with more insulation on the interior. A concern from a tight house is fresh air exchangeAgain, codes, but all new houses are built with air exchangers, our houses are called "Super Seal" or "P-2000", they are sealed. A non-foamed house will breath through the cracks in the skin, but a foamed house has very few, if any, cracks....only opening and closing doors and windows will let fresh air in (well a fireplace is an opening that will allow breathing). I was so concerned about this that I installed a fresh air exchanger (to conserve energy). I also went geothermal ....great move, from where I sit.
Some negatives, besides price, is remodel-ability. It's hard to scrap the foam off of the wood....it's almost impossible to pull wire after the foam goes on. Some say that foam isn't as fireproof as fiberglass...but it does put a barrier between the fire and the wood. Some say foam gives off an orderThis is called off-gasing, I believe most people should not experience this, from my research it's said to be caused by a poor quality instal(Spraying to much foam at once, the foam will get so hot due to the chemical reaction process it will start to bake itself....I haven't detected one yet. Some say foam will eventually harden and crack....mine has changed color, but is still quite in tack. I'm sure there are other negatives to foam....these are the ones I can think of off the top of my head.
I see where a combination of both systems may be the way to goI commented a few weeks back about a top-of-the-line Energy Star home we were envolved in, the whole house was spray foamed, we went back to blow R40 over the existing R20 spray foam sprayed on the attic floor, it is an extremely expensive option, but I will admit the system is quite interesting.. But I still think it's a personal preference on which way one should do. Do your research. You need to weigh all the pro's and con's to decide which is right for you. But as it was stated in an earlier reply, energy prices are going up.....so insulate all you can.
IMO, foam is still too damn expensive, and honestly I don't know why it isTrue story, we quoted a mansion type build, one of those small acreage a step outside the city deals. They originally wanted sprayfoam because of all the hype, the sprayfoam quote came in at $60k, we came in at $15k. Guess who got the job?. I would use it for a small remodel job, or places where the thickness of insulation is limited (and high the high R value foam), but damn, is it expensive!!!
I have read about some installations where spray foam is used very minimally on the "cold" side of the wall, just enough to seal it, then blown in insulation is used to fill the cavity. I guess this was done to get great sealing (I guess some really prefer sealing on the "cold" side) and still keep the costs down, with using primarily a "cheap" insulator. Best of both worlds maybe?
A while back Fine Homebuilding magazine had all sorts of different efficient insulating designs described. It was interesting to see just how many ways you could do this. One design even used the I-beam wood floor joists as wall studs to get insane wall thickness (and high r value), some others used foam panels on the exterior. There was so many options it would make you dizzy.
I also just read about these options, not only are there many ways to construct a home to insulate it better, but beyond traditonal insulation and spray foam, there are many ways to have you home insulated. Search 'Bib system', radiant barriers, spyder system, just to name a few.
In my shop buildings I like 1.5" foam sheet between the outsidewall girts,then a low perm foam wrap,tape the seams and steel side.Wall girts on the inside with glass batts in the cavity,then more 1.5" sheet between the inside purlins.
On the cieling I used 1.5' foam sheet between the trusses,then purlins 24" oc with 1.5" sheet foam between, then VB and steel.Then blow in 18" of celulose. I can heat that place with a candle when its done that way.
My comments in red are not ment to be critical, just for the sake of the discussion.
When I first joined here I thought I'd be able to help out a lot as there are a lot of questions about insulation here, but I quickly learned that depending on your region in North America, things are done quite differently from one province or state to the next. I want to post a picture of how we do things here so those interested in what I'm blabbing about might understand my position better(I'm posting a picture marked with my business lettering to try and deter web-thieves, it's not meant to 'promote' me or anything, as most of you live very far away), this is one of my best photo's that show the detail in what we do in every house:
This photo is of a house freshly finished with Batt & Poly. It would be boarded next and then we'd go in and blow in the attic's as per the home-owners/builders wishes.
Things to note in the picture: Walls are built with what we call "Transition Poly" which we tie our poly into and inturn creates a continuous vapour barrier on the ceilings and walls. Windows and doors are foamed with window grade foam, the excess space is stuffed gently with fibreglass insulation and the window is caulked with acoustical sealant which seals the poly to the window/door. All penetrations are caulked, taped or foamed(Wires, pipes, or anything that penetrates the thermal envelope.). Poly pans around electrical have the wire penetrations sealed and the poly pan pulled through and taped, or for potlights, the pan is stapled to hard backing and caulked to the VP. You'll also notice that all poly meeting poly is sealed together, and rooms and walls are done in as few pieces as possible. We commonly use 20ft wide poly, the biggest pieces I've put up in one solid piece is in the 1000-1500SF range, I'd kiss the man who first made 6mil poly available this wide if I had the chance, less overlaps and connections = less chance of an issue with the seal.
I consider what I do kind of an art, and I try to take pictures of every property, so If anyone would like to see more, just speak up.![]()
Things are done a lot different here where I'm at, I've been in a lot of houses and never seen one done like that, typical here is tyvek house wrap under the siding, osb sheathing, fiberglass batts with paper facing and then drywall. I think a house done like you do it would compete with foam pretty dang good. One question I have is how do they attach drywall to the studs with the poly there? no glue I take it? Here drywall gets glued and screwed but I don't see gluing to the poly helping.
