Coolant tool
1320stang
Edmond, OK
Scott, the cheap one works fine, but you have to do a little modification to it. It takes a little time, and you need to be dexterious to an extent, but I think even my 7 year old could do it. You save a lot of money this way for a little time, here's how you do it.
Danglerb
SoCal
Just wait til HF has it on sale and try it, you can always buy the Snapon later.
Danglerb
SoCal
Doesn't the Lisle spill free funnel at least attempt the same thing, getting all the air out?
J
jimmycrackcorn
Brooklyn, NY
I actually want this to save me time on filling the cooling system, i really hate bleeding and having to wait for it to circulate to get most of the air out of the system....
ImportTuner
I have a similar tool made by MityVac which does the same thing; it fills the radiator with coolants and at the same time removes air so that no air pockets form ... works really well ... :)
Fedwrench
Valley of the sun
I have the Uview model and it works great. Ford even has it as an essential Rotunda tool. You want to be careful about two things though. First, I have seen the rubber radiator neck adapter get stuck. A little Wd40 beforehand cured that. Secondly, I wouldn't use it on a marginal engine. When you pull the vacuum if the intake gasket or heater core are marginal, they'll let you know by starting to leak. Also prime the hose with fresh coolant to remove any additional air. It's a timesaver once you get used to it.
Franz©
in a house
Dammit, another idea swiped from me.
You can accomplish the same thing with a vacuum pump and trap and the cap from a pressure tester.
