garfunkle24
Vibration
It took me a fairly long while as a mechanic to understand the true value of vibration and how much it can help you.
My air hammer (PH3050) get used daily, but you don't need an air hammer to use vibration to your advantage.
1. Take a tapered punch and give the broken bolt a few good wacks. This will help break the rust bond between the fastener and housing. This will also let penetrants in there to work their magic.
2. Next I take my (Air)hammer and spend a while hitting all around area the bolts are stuck in I then like to use my penetrant and then give everything another good vibrating.
3. Once ready for the extraction, have someone beat on the housing (or vibrate with an hammer) the whole way through the extraction.
Vibration has lot more uses than just loosening broke bolts though. Vibration, particularly in combination with heat, is very effecting in both the installation and and removal of press fit parts.
One good example if pulling a pulley from a shaft. The pulleys we usee at work are aluminum and fairly easier to break. I set up the puller with some tension on it, but stop shy of breaking the pulley!
I then apply my air-hammer to either the centre of the pulley or to the end of the puller pressure screw. After this, the puller should loosen up slightly. Tighten up and repeat. If you can, have a buddy run the air hammer the whole time while you wind on the puller, it works even nicer. If you got 2 buddies, you have 1 running a torch, one with an air-hammer and one cranking the puller!
