I just spent at least a half hour reading this thread from post #1. I have dabbled in many of the processes shown here as a hobbyist. I'm afraid I'm a bit of a kludge by comparison. But, having tried makes me appreciate what I've seen even more.
However, you guys are so good at your craftsmanship that I'm afraid a lot of GJ members won't post here for fear of being embarrassed.
So, let me open the gates to others that struggle along and show you something I did several years ago in the beginning of my foray into metal work and car restoration (or mostly rust repair as many have pointed out is the bulk of the work).
This is the lower portion of the rear quarter of a Porsche 911. It's a common rust repair that comes with replacing the rockers, lock post and sills (already done).
This is the worst pic and it shows every flaw in the work. When finished, it looked fine and painted out well. You can see I missed the radius that matched the door. I was able to save that with a little more work with a hammer and filing a bit off the door. the door was from another car ad Porsche doors don't always fit the same anyway.
The piece is rolled to fit the body contour. Then I formed the flange. I had read about a trick and I did it. I cut a slot in the end of a 1/2" steel dowel that fit over the thickness of the sheet metal and cut it to the depth of the flange.
By slipping it around the inner circle and bending a degree or two at a time, eventually you will get your 90 degrees. I remember that winter and my carport/shop was wet 24/7. The rust looked like that overnight even with Ospho. But I got 'er done and went of to some interesting "rustoration."
So you guys that are just readers here, post up some stuff. The guys that are the best in the business would be the last guys to criticize you and I know that.
