Wall Stripes Question
reb162
Dayton, OH
I'm painting my garage,all in semi gloss. Ceiling and top half of walls are going to be white, bottom half of the walls will be grey with a 2 inch black, 2 inch white, 4 inch blue,2 inch white, 2 inch black stripe combo seperating the white and grey on the wall. I've painted the ceiling and I'm about ready to hit the walls but I want make sure I do this right.
I had planned on painting slightly more than half of the walls white, taping off for the grey and then painting the grey and slightly overlapping the white and then taping and doing the stripes.
Question is, if I paint the top half in two coats of semi gloss white, and then paint the bottom grey , will I see ridge lines from where the white stopped and the grey slightly overlaps? Should I just paint the entire wall white and then do the grey?
Charles (in GA)
50 mi south of Atlanta
Take deep breaths, breath slowly, and repeat after me, "its just a garage".
Seriously, you might be able to see an edge if you tape, but if you plan on overlapping, why tape the white, you will have a less sharp edge that way.
Charles
CraigP
Gray over white, you should be fine. Think of it this way, primer is usually white, and you don't see that through the top color, so you'll be alright. You may have to just hit the gray with two coats to make sure the white is covered fully.
But, be warned. I just painted my garage last night, satin white. Before I painted it was an old, tired, probably faded white or light beige color. I checked it out this morning and it looks like ****. Where the original tape lines are (under the original light beige paint) is much more white than the non-taped areas. The non-taped areas look a little yellow. There was even a water stain on the wall from when I was cutting tile that is showing through the new white (two coats). Basically the walls looks like a big grid. It looks like ****, but as Charles said, it's just a garage. It is brighter and cleaner than what it was and it's going to get dinged and dented so it'll do.
Falcon67
Merkel, TX
You'll want to wet sand the entire wall and then roll at least two coats of clear over the top. LOL! ;)
csp
Franktown, CO
After primer take a chalk line and snap a line where the middle of the 4" blue stripe will be. Paint both the white and grey almost to that chalk line. Since it's almost, it will naturally feather itself out and you won't see a line once you paint the blue stripe. You will probably see lines at the edges of your other stripes though.
I'm wrapping up something similar on my walls. Should be done with the stripe tonight.
Greatbear
Columbia/Fulton, MD
I have always been an advocate of painting garages and workshops with a darker color below the "beltline", usually blue or green. This will tend to hide dirt and stains that inevitably happen when working in a garage as stuff gets kicked up against walls from the floor, vehicles and machines.
R
reb162
Dayton, OH
Thanks all for the tips...the white semi did not leave any apparent lines. I'm going to start the grey today.
Also, I'm looking for the stripe to be Ford blue. Whats the best way to get Home Depot to match this in Behr Paint...does anyone know of a Behr color that matches pretty close?
dfmkevin
Ukiah California
I'll be watching to see how yours turns out as I am goint to be painting in a couple weeks.......
dankicksass
New Jersey
I'd paint my garage in Gulf livery, but it's mostly bare block so I'll settle for leaving it as-is, until I figure out how much it will cost me to re-roof it the way I'd like.
Jackfre
N CA
It's my understanding that, to avoid a ridge at the color separation the tape should be removed while the paint is still wet. Tends to flatten it out.
R
reb162
Dayton, OH
Well,
I got the line dividing the white and grey taped up tonight and put a light coat of white on the one edge to seal the tape before I paint the grey tomorrow (Pics below). My new Dewalt laser line level made staying level real easy.
White painted over to seal the edge
R
reb162
Dayton, OH
Which one of these blues does everyone like better for the stripe...I'm trying to get close to ford blue:
Behr Southern Blue
Behr Sapphire Lace
Responder
Saskatoon, SK
I do believe that the first color is closer to the "ford" blue. However, I kind of like the second color myself!
Good luck!
R
reb162
Dayton, OH
First coat of grey went on this morning. It adds alot of color (or at least contrast) to the scheme...the all white was starting to freak me out.
csp
Franktown, CO
You can take something in to Home Depot that's Ford blue and they will custom mix a color that matches it. You're not stuck with the colors they already have mix formulas for.
Chloe Taylor
Charles
Nice idea, surely this is what you must be going for....:thumbup:
R
reb162
Dayton, OH
Problem is I do not have anything here that is Ford Blue...I could print it from my computer but I do not trust the computer and printer to replicate it.
Second coat of grey is done and tape is removed....I'm real pleased with the sharpness of the lines. Only one or two bleed through spots that can be touched up.
DrunkSmurf
NorCal
Looks good so far. I'll be attempting some stripes myself soon.
On the Ford Blue. Go to an auto parts store and buy a rattle can of Ford Blue, take the cap to paint store to have a color match made.
Return or find a use for the rattle can.
Good luck with the remainder of your project.
R
reb162
Dayton, OH
Thanks...working on lights tonight...stripes probably will not happen til next weekend..I'll post then.
The Grey is Behr "Gray Area", code 770F-4 in semi-gloss
R
reb162
Dayton, OH
OK. Got my stripes done and I thought I'd share. I think they turned out great. Only minor bleed through in a couple of locations that I need to touch up. Also got all my flourescent lights up which you can see...place is super bright now. Next step is to buy the cabinets and paint them and install them.
