countrytech
Per: http://garagejournal.com/forum/showthread.php?t=101506 I got another drill press and even tho I want to keep it, I think I should probably at least try to sell it, but I want to clean it up first and make a little off of it if I can.
So far I cleaned some of the dirt with multi-purpose cleaner and then sprayed PB blaster in the table clamp to loosen up the rust. I sprayed some PB on spindle too, as it seemed to have a very slight amount of rust starting. that seemed to free everything up nice and then I got the column wire brushed and sprayed WD-40 on it hoping to keep everything in rust free condition.
1. Was (is) it a good idea to do everything I did so far?
2. PB blaster isn't going trash anything, right? as I understand it seems to act as a partial lubricant and loosens that rust and grime up so that stuff moves free-er, right?
3. What can I do to smooth up the table some more? all I have at this point are wire wheels I put in my hand drill and run at high speed. That takes the rust off and did a good job on the column, but it's not doing anything other than removing rust on the table. I'd like to smooth it up some if I can without too much trouble.
4 Is WD-40 a good thing to spray it with or should I do something different? My idea is that the WD-40 will help prevent rust and keep everything moving properly...
I know I'm not real skilled and the press still looks a little rough, but I'm looking for help. Where do I go next?
BEFORE
AFTER
View media item 9833
BEFORE
AFTER
