I want to order a filter/regulator this week to get my compressor hooked up. I am looking at this one on Amazon: Ingersoll-Rand (IRTC38221610)
The only reviewer writes this about the unit:
"While I'm at it, keep in mind that this regulator has a pretty substantial pressure drop as the CFM goes up. For example the regulated pressure is 10-15 PSI less at 10CFM than what you set it to when you are not drawing air out. At its maximum CFM rating the pressure drop across this is about 30 PSI. This is true for almost any regulator of this size, so make sure this fits your application."
What do you fellows make of this? I really don't know if it is something that I need to be concerned about. My intended use for the compressor (60 gallon CH, I think) is to run a blast cabinet, air ratchet, 1/2 impact, maybe some sanders etc.
