School me on blast cabinets
TAftw
Well I got a 5 gallon sandblaster for free from a forum member. I don't want media flying everywhere, nor do I want the mess in my garage, so I want to turn it into a blast cabinet.
How would I go about making it so all the media collects at the bottom so I can use it again?
Does anyone have some cabinets they built that they'd like to post up? Thanks :beer:.
Here is the blaster in question:
buildmyown
Franklin Ma
Nice little pressure pot there. Do a google search for homemade/homebuilt sand blasting cabinets. Before i bought mine I was looking into making one. If you wanna lay out a little money upfront TPTOOLS.com sells a kit and plans to build your own out of 2 sheets of ply wood.
ozyborn
I looked at the HF floor model. Then made my own out of plywood, sealed the seams. Went to TP tools for the glass and seals. I put air fittings on it. For suction I just connect the air hoes and use the suction blaster. Put the tube in the bottom and just keep recycling the media. For using the pressure pot I just connect that up to the cabinet instead and use the hose fitting from the pot blaster. Works like a charm...
T
TAftw
I plan on making something like this. And it won't be a "benchtop" model. I want to make it as big as I can.
djjsr
In the cornfields
I have the HF floor model and it works ok for most stuff. HOWEVER, I put a 17" wheel in there and it was a pita. The cabinet needs to be about 8"-10" deeper (front to back). Width is fine, could be a few inches taller. So, if you plan on building one, make it bigger than the HF cabinet.
rsanter
visalia ca
free 16ga material
free lexan window
free pressure cyninder
welded it up and this is what I came up with
works great. I also have the same HF blaster that you have and it works great
bob
peterj
NC
Got a TIP-960 and couldn't be happier with it after I got their ******** to get the blast media to the pick up at the bottom of the chute. I thought I wasted my money before I got the ******** because material flow was hit or miss at best. Humidity here in NC will really affect the flow of your media material. My advice, bigger is better, get a good moister filter and have the correct air capacity compressor (I have a Quincy QT-5) for your gun.
jk1219
Here is the Cabinet I recently built. Made it out of 4x4's, 2x4's, and a sheet of plywood. Cabinet area is big enough for motorcycle frame, rims, plenty big for anything I have needed to blast. Just make sure to seal it up very well and you should have no problems!
