Transmission/Oil Pan Plastic Holders
blare
I saw some transmission pan plastic guide "bolts" on a truck show on the SPEED network but can't find them on the internet. The basic idea is that they hold the pan and gasket with these plastic guides so you can put the bolts in. Anyone know what I am talking about?
Mr.Nutcase
USA
Felpro makes them, I bought a oil pan gasket for a car, the plastic holder came with the gasket set..
scott37300
Wisconsin
Advance auto sells them. I can't remember what they call them but felpro does make them. There was a thread a couple months ago and I posted a link in it to them. Can't remember the name advance auto calls them and it took 20 minutes of searching last time. I'll see if I can find that post for you.
bchee
Texas
Those are interesting. Never seen them before. Why do they have male thread on the bottom?
Sterff
PA
I would assume you thread the holders in to the pan and then press the pan on. After you had a few bolts in you would remove them.
Shadowdog500
Down the shore
Snap On used to sell Gasket Klips that worked really great. the metal clips held the gasket in place so you could position the pan without it moving. They would work pretty well in conjunction with the AutoZone clips.
I wish they still sold these somewhere.
Chris
Item S in the catalog shot below:
Here is an illustration of how the worked from the patent.
scott37300
Wisconsin
Pretty sure these will hold the gasket in place also. If you look at them they thread into the block and then have a 1/2" or so space and then a lip. So the gasket can slide on and sit on the lip while you put the pan on.
lilredex
Toronto
When there was a risk of the gasket shifting on pans, we tied a string through a couple of the holes to keep it in place. The string could be cut off after starting a few bolts in their holes. Same thing?
Shadowdog500
Down the shore
Chris
Signcrafter,
Thanks for the PM about these Klips on E-bay. Pretty neat when a two year old request for a long discontinued item pays off. I bought some and figured that others here may want some so here is a link.
Chris
http://www.ebay.com/itm/GASKET-KLIP...Parts_Accessories&hash=item3a79ac2e55&vxp=mtr
scaron
ypsilanti, michigan
oh man we've got some good ideas in here for holding gaskets in place. i never considered using a piece of string, amongst other things. thank you all!
619DioFan
San Diego , Ca.
This. been doing it this way forever. I use a few small zip ties. great way for oil pans as well.
