Back from our racing diversion so this is a little out of sequence but to continue with the clutch replacement prior to the race. While Cameron was in the barn working on the car I noticed behind him...
...he was using a roll around cart to place his tools on...
... and rather than just piling them in a heap he kept them in an organized manner. Over the years I've only made suggestions on work methodology and practices and some of them seem to be taking hold.
Oh, BTW, before it comes up, I just noticed...yes the screws slots on the cart are clocked. Remember those work methodologies I mentioned earlier...some habits die hard I guess?
While replacing the clutch we found the clutch linkage "Z" bar had some cracks on the end levers ...
...both ends, so those were repaired and reinforced so that will never happen again.
Once that was completed it needed to be...
...powder coated of course!
When it was installed...
...it didn't look out of place. It will be durable and should look good for many years to come. Do it right once and move on.
The bell housing, now cleaned up, was installed with the new clutch...
... transmission and linkages installed and adjusted. Then of course he had to try it out at the track and it seems to have worked...
The first day of qualifying he made 27 passes! There's no replacing seat time is there? How do you get to Carnegie Hall?....practice, practice, practice!
Thomas
