Garage Sale Tool IDs
newcastleadam
Gainesville, Fl
Need some help ID'ing some tools I picked up over the weekend.
First some group shots of the haul:
Specifically, got questions on the following items.
Trying to read the date code off a Snap On 71N ratchet. Looks like it got hit a few times.
Any date estimate etc on the Snap On Torqmeter (nameplate is banged up)?
Then this Snap On CF-7B, no idea what it is.
Text reads: "Push both bars forward load one lock at a time. Push the locks onto the valve stem at or below the retainer grooves pull back lower bar. Let the tool hold the locks lower the valve spring."
Last are some 3/4" ratchets and sockets.
Thanks,
Adam
Thumper
N.E.Ga
Cool Stuff......good score. In the metal box I see a pilot bearing/bushing puller. A valve spring keeper tool.......an air powered valve spring compressor....some neato Snap-On ratchets......a couple of ball joint/ tie rod seperators (AKA pickleforks)....nice haul !!!
N
newcastleadam
Gainesville, Fl
Need to put the date code under a mag glass and crazy lighting, see if it'll pop out better. Here's a pic of it cleaned up a bit. Cool brass select lever (wartime shortage?).
Other items of note:
Ridgely wallpaper trimmer, Pickering lunch truck temp gauge, Snap On LSF720 (crazy looking 1/2" in a 3/8" body, think only made 75-78).
Going through bits and cleaning them, figuring out what I want and don't want. Might try soda blasting the 71N. Best $61 I ever spent on tools :)
N
newcastleadam
Gainesville, Fl
Just found out some info on the Curtis "Swench" wrench-the 3/4" version provides 800ft/lb of torque, and is used for torquing the prop retaining nut on large propellers mounted on radial engines. Power Hawk owns the brand now, and still makes them. Linky.
BlindViper
York, PA
Snap On CF-7B the patent was file nov 30 1936
its for installing split cone valve spring retainers
humber2
Downunder
The 5/8" drive one, Model 625, is good for around 500 ft/lb.
What make are the sockets that work with it?
Great deal getting a 750 as well.
Them's a great tool. :beer:
