I have a 3" hole in a tractor hood that I want to enlarge to 4-1/2". What would be the best way to go about this and have it look proper? Or should I say, what equipment would be needed and what type of place should I be looking for to do it? Thanks
If you have a hole saw kit, clamp a 2x4 to inside of hood under hole the use 3in hole saw to get center,( just the small pilot hole) then use that center hole an put a 4 1/2 saw in an cut.
Is this hole round? Or oval?
Starrett Oops Arbor a19, Put a 3" saw on the inside as a guide, 4.5" on the outside, done.
That's awesome! Didn't even know that those existed. This forum rocks![]()
I'll guarantee you that if he uses this he will have blisters larger than the hole he's cutting!gauge-air-nibbler-96661.html[/url]
...or they make a hand version as well.
http://www.harborfreight.com/compact-hand-nibbler-65895.html
If you think that a hole saw will be kind to the paint it's obvious that you have never used one. The best tool would be a large hydraulic knock out punch or a sharp pair of aviation snips./
Not lithium crystal driven, but very handy.
