Enlarging an existing hole
HookWorse
Iowa
I have a 3" hole in a tractor hood that I want to enlarge to 4-1/2". What would be the best way to go about this and have it look proper? Or should I say, what equipment would be needed and what type of place should I be looking for to do it? Thanks
king nero
Belgium
tractor hood => how thick is that?
could you use a saw like this, with the appropriate blade? + finishing with a dremel or file?
Rentawrench
Holyoke,Ma. USA
If you have a hole saw kit, clamp a 2x4 to inside of hood under hole the use 3in hole saw to get center,( just the small pilot hole) then use that center hole an put a 4 1/2 saw in an cut.
Jim Stabe
San Diego, Ca
Trace out the new hole outline and use either left hand aviation snips (red handles) or a saber saw with a fine tooth blade. You can lay masking tape around the outside of the hole if you don't want to scratch the paint.
Underdog
Treasure Coast, Florida
+1
Also for holes that you can't get under well, I've made a wood dowel from scrap and driven it into the hole just tight enough to drill, find center, re drill, knock dowel out.
H
HookWorse
Iowa
Wow, and I was expecting you guys to say there is some ultra sonic hyper driven lithium crystal boring device that is the only way it can be done. :beer:
H
HookWorse
Iowa
Is this hole round? Or oval?
Round hole, where the muffler goes through. Right now, the pipe comes up out of the manifold, through the hood, and the muffler clamps to it. I want to shorten the pipe, and lower the muffler so the clamp is under the hood instead of above it. As it is, to take the hood off, you have to remove the muffler because the hole is smaller than the diameter of the muffler.
back2class
I would also think a round ginder, either a disk/wheel in a die grinder or a small drum insert for a die grinder with good oxcide paper on would work well. Just follow the outline you would draw first. I would use the hole saw if you have them and die grinder if you didn't and own die grinder. Snips will bend the steel too much.
bad_idea
Pasquotank, NC
i have been meaning to buy one of those starrett opps arbors! this sounds like a perfect project to buy one for. (you, not me tho)
gorilla
If you think that a hole saw will be kind to the paint it's obvious that you have never used one. The best tool would be a large hydraulic knock out punch or a sharp pair of aviation snips./
klhitman
pewee valley
what i have done to make a large hole larger is take a hole saw of the size i want and put it on the arbor and then put a hole saw of the size that is already there inside of the hole saw that i need. works for me and keeps it it centered
Milton Shaw
If you have an electrician friend he might have a greenlee slugbuster Knockout punch that would do it with just a few turns of the wrench. Knockout punches are used to put holes in panels for conduit and a 4.5 inch is probably available. My set of punches goes to about 2" but an industrial electrician would have bigger ones. You might be able to find one at rental yards also.
speed bump
Butte Montana
Mask out where you are cutting and your good to go. Good luck cutting a tractor hood with aviation snips.
hunter1151
Kansas
This is especially true if it isn't flat!!!
Frank The Plumber
Chicago.
fasten a piece of hardwood to the back side of the 3" hole using screws within the 4 1/2" dimension. Center a pilot hole in the center of the 3" hole into the hardwood. Use a fine 4 1/2 "metal bit with a pilot bit into the hardwood hole and lubricate with a dish soap and water solution this will help to cool the paint so it does not shrink peel from the heat.. Be patient and hold the drill steady or use a press if you have one.
Do a test sample first to be sure your bit won't catch and travel.
H
HookWorse
Iowa
I called a guy I know in a commercial electric company, asked him how big their knock out punches go. He said, 4-1/2", why?
:D
nkachur
Manitoba Canada
I would second the knockout punches. They produce a beautiful smooth hole with very few burrs and no real cleanup. Only downside is they are pricy to buy.
Alchymist
Central PA
Check the actual size on electrical knockout punches - they go by pipe size, not hole size. Actual size is usually larger than indicated. Example, 2" KO will punch a 2-1/2 inch hole. "Chassis" punches, used in electronics, however, punch indicated size. Just something to be aware of.
