Alright! Update time!
I made the final touches on the cabinets before priming. I had to do a little more bondo than I thought, but it turned out real well. I was pretty upset when I pulled the door off and ripped some wood, but the repairs have been made and I think it looks good.
Funny thing...I call myself a perfectionist, but a true perfectionist (I guess I should say a 'professional' perfectionist) would probably just laugh at me. These cabinets are far, far from perfect. The plywood I used for the flats was actually a real rough grade of plywood. It was repurposed so I don't feel bad since I got to reuse it, but if I was starting from scratch I definitely would have gone with the sanded stuff (and if the budget was limitless). The curves aren't perfect. Heck, there is even a 1.5"x1.5" chunk missing from the plywood shelving where I slipped it into place on one of the top shelves (now that I think about it...ehh...I do want to fix that lol).
All that to say, they are not perfect, but I think they will look acceptable when done. It was a good learning experience. Next time I'll have to get that ball bearing router bit dangit!!!!!!!!!!!
Okay, enough words, more pictures!!!
Before priming:
By
daveamy at 2011-07-10
By
This door is smooooooth and it even stays closed on its own!
By
By
By
And with the first coat of primer:
By
By
By
Honestly, this isn't very exciting haha. Once the paint is on, things will really start taking shape. I'll also have to do a lot of touch up. I didn't bother masking off the wall for the primer because I needed to do some repainting of the wall around the cabinets anyway as there are lots of gouges, scratches, paint, pencil marks, etc.
Here is what's next, in order:
1. prime #2
2. paint
3. cut, finish and install from facing plate (apply Craftsman decal before finishing)
4. route trim pieces
5. cut trim pieces
6. finish trim pieces (boiled linseed oil, just like the good ol' days)
7. install trim
8. install flashing strip around the bottom 2 shelves and polish for chrome-type finish
9. make and install art deco strips on trim pieces
10. make side accent pieces for each end of cabinet
11. run electrical to the center piece and the far right side and install fluorescent lights and halogens
12. cut holes and run rope lighting throughout cabinets
13. make and finish under-folding swing down access drawers underneath the bottom cabinet ledge
13. touch up EVERYTHING because it will be a mess
As you can see, I've got my work cut out for me. I don't know if I'll really get too far into this list before the kid comes, but as I get breaks, I'll be knocking things out
