Best lube for ratchets????
gatewaysysop
Arizona
So sk frankenstein 36 tooth would be bad with marvel mystery?
Oops 32 tooth
Just picked up a 3/8 Frankenstein off eBay ($50 shipped :shocking:). I think I counted 36 teeth, checked twice, but either way I wanted to point out for those reading this thread that I cleaned it up and lubed using Super Lube and, despite being very well worn, it ratchets real nice in both directions now. The selector/pawl mechanism also got Super Lube and it works much better now. :thumbup:
Too bad it's near impossible to get gut kits for this, I'd love to completely rebuild it. It looks absolutely mint on the outside and could pass for brand new after I cleaned it up. :drool:
gatewaysysop
Arizona
Where do you guys find superlube? I've checked HF and True Value, 2 places that are supposed to have it and came up empty.
Amazon has it and so does eBay. I'm surprised your HF doesn't have it, but to be truthful, I didn't see it at mine all the time either. They only carry the big tube, so if you're looking for something else maybe you missed it?
In any case, the prices aren't much different between HF and Amazon or eBay.
Here's the HF link, they claim in-store only so maybe they have it somewhere and you just missed it? Or maybe they can tell you which stores have it? Link
Here's Amazon's link for the same thing.
Either way, that's practically a lifetime supply for lubing ratchets. :beer:
Hope this helps!
Aklass
Anyone try Molly Lube? or is that too extreme and will cause slipping?
mkdive
NPB (Socal)
images
chewy7
WISCONSIN
Well i have tried 85w140 gear lube in my craftsman 1/2" 44996 thin profile ratchet. It seams to work better than some clp that i had. and no.2 amsoil grease made it to sticky.
48548
Phoenix
I use mobil 1 synthetic grease in a tube, it is red and works well in my plumb/proto and snap on's all way up to the dual 80's. It is pretty cheap for 6 a tube or so and works on a lot of things....
chewy7
WISCONSIN
I have that stuff too in a tube being unused. Right now i had amsoil in my grease gun so I tried to use that stuff. Maybe i will try some mobil 1 at a later date.
JayL
Manila, Philippines
Is Super Lube ( 400g )and Marvel Mystery Oil (32 Oz ) available at Advance Auto Parts, Orielly's or Auto Zone? I can't seem to find Super Lube on their websites.
Thanks
gatewaysysop
Arizona
Thanks
I was never able to find it at Orielly's or any of the other parts houses, but stumbled on it unexpectedly at Harbor Freight. Lifetime supply for about $5. I think you can find it on Amazon in larger containers if you need/want that much of it.
ajchien
Los Angeles, stuck on the 60 freeway.
Ok, so I finally found some superlube at HF.
Previously to superlube, I used CRC brake caliper grease, and standard lithium white grease. At first there seemed to be very little difference in my raised panel CM ratchets. But now, 2 weeks later, the ratchets are much smoother. Delayed response? Just the grease taking time to even out? Put too much grease in and now some has squeezed out? Don't know. But I'm happy with the superlube result.
dirtrider
I just use regular old Pennzoil 30w oil, I find grease get's gunky after the ratchet sits for a couple of days and air tool oil is just to light. Never tried the red lube or marvel mystery oil .
asp
Westport, MA
I tore apart my new-to-me Blue Point UR72 ratchet head today (32 tooth). It was pretty gross inside when I opened it up. I cleaned everything out, and packed it all with multipurpose grease, and put it back together. It's leaking out of the openings, but I'm slowly wiping it away as it oozes. The action is very, very smooth.
chilly460
Digging up this old thread. I've torn down roughly 10 ratchets lately of all different designs and sizes. I've used some Redline assembly lube I've had laying around, it's more like a grease, but it's pretty light. I like it because it doesn't leak out, it clings to places where you want it, and it won't dry out like some other types.
That said, I have found with ratchets with a light detent spring, it can be a little too thick and cause issues, I have Snap-on 730 that i had to take back apart and clean out because the pawl just wasn't engaging the teeth enough. Otherwise, it has worked in everything and quiets them all down.
BrokewrenchLS1
WV
Interesting that it hasn't been mentioned, but I've used MagnaLube for all my tools. Carried it over from my gun stuff, and a very light coating works great and seems to last quite a while. Inexpensive, too.
Sterff
PA
It all depends on the ratchet. Fine tooth ratchets such as 60 + tooth models I would only use an oil. Courser ratchets I tend to use grease. I use 3-in-1 oil on my 60,72,80,88,and 100 tooth ratchets.
jk47
I agree, but use Marvel Mystery air oil for fine tooth :thumbup:
Singlecut
Great Falls
I let them soak overnight in ****** fluid.Even rusty ones usually free up
after a soaking.
Agree 100%.
I got a used S-52 off eBay and I soaked it for about a week in ATF. Every morning or so I'd walk out to the garage, pull it out of the soak, attach a 1" socket on it and spin it upside down. TONS of black crud came out. I didn't want to take it apart as these things are notorious for flinging components.
So I did this until only crisp-red ATF would leak out. Man does this ratchet purr. I do this to all my non-sealed heads now.
Actually, I do this to a lot of my tools. Pliers, swivel joints and ratchets get a cycle in the soak. It's very meditative just sitting and cleaning them. It's been like 90+ degrees here in Denver so I'll set the jar out in the sun with the tools soaking in their lovely bath.
Paco Pena
Vancouver Canada
I used to use multi purpose grease in mine till it caused issues in really cold weather. Now all the non sealed ones get a soak in ATF. Just leave then standing upside down in a coffee can to drain afterwards.
Paco
jstutzman
North Carolina
I just cleaned 4 of my ratchets out last night and relubed them. I only do this about every two years. Here in NC it is fairly important to lube your tools as it gets very humid all summer long. That said, i used 3M oil and have not heard anyone mention it on here. It does seem a little light and i was thinking about using a bar and chain or gear oil. Maybe even a light lithium greese. Im didnt use the greese becuase i had take some very old ratchets apart that had a lot of dried up greese in them. Actually picked on up at a flea market becuase it didnt work and all that was the matter was it was gunked up. A little carb cleaner and some oil cleaned it right up.
Dustin Crawford
I prefer reg leftover grease. I have tried light oil and 90w but prefer grease because it stays in there a long time and tales away the 'clicky' feeling of my matco 88 and newer craftsman stuff. It makes older craftsman stuff feel like butter.
