nismomans13
So I have a older miller tig machine, it has a 75ft power cord on it. WAAAAAAY more than i need to get around the shop. However, I do need a larger gauge wire to run to my welders outlet. Would it be possible to use this as outlet wiring? as in, from the breaker to a 50amp socket.
Its only 3 wire, so there wouldn't be an actual ground in there, but my 240v outlet doesn't have a ground hook up. Just the 2 hot and common. Is this possible, or should i just go buy some 6/3 romex? Btw, I don't know the exact gauge of this wire, but I know its bigger than 6/3 romex. In my welders manual it says that it can be wired directly to the breaker or with a plug. This is why i'm wondering if I can run part of this cable from the breaker to the plug.
