What size ground wire for 8 gauge THHN?
thammel
Maryland
I'm installing a standby generator (actually re-doing the wiring so it is correct and per code). The current power feed wire from the genset to the transfer switch is in PVC conduit but is NM 8 gauge. I know this should be THHN but here's my question - what gauge should the green ground wire be? I think 10 gauge is ok, but want the experts' advice. I checked my stock of NM and found some interesting info - I have some 10 gauge nm that has a 10 gauge ground wire and is so labeled. I also have some 8 gauge nm that has a 10 gauge ground wire. I even measured them with a micrometer to verify they are the same size. Both are 3 wire plus ground. Interesting!
Thanks!
Tom
TheEquineFencer
Farmville, NC 27828
Just out of curosity, what's the genrator rated, Amp/Volts, generator breaker amp rating ? How far away from the the transfer switch is the generator mounted?
T
thammel
Maryland
It's a Winco 8kw. 240 volts. Max current at 240v with propane is 33 amps. Been working fine but need to change from nm to thhn in conduit.
Tom
ishiboo
Oshkosh, WI
Thanks!
Tom
I believe you'll need a #10 for #10 wire. A #10 will still work if you are running #8 hots/neutral.
T
thammel
Maryland
I know that thhn has a slightly higher ampacity rating than nm sheathed. From what I see 10 thhn is good to 35 amps and 10nm is good to 30. 8 thhn is good to 50 but 8 nm is good to 40. Now, my genset puts out 33 amps max. So you'd think 10thhn would be ok. But the Square D on-line table says to limit 10thhn to 30. So I'm perplexed. I think it's safer to stay with 8,but cheaper to use 10!
Please comment on ampacity for 240 volt 33 amps!
Thanks!
Tom
ishiboo
Oshkosh, WI
Thanks!
Tom
I don't think there is a separate spec for generator feeds as there are service entrances, nor does the generator feed qualify as service entrance, but if there is I may be wrong with the below.
Code would dictate a 30A max for #10. I would run #8 with a #10 ground. As you know, that's good for 50A in conduit. You'd be at the VERY top of #10's capability (and, by code beyond) and the #8 would give you some decent expansion room.
