I'm installing a standby generator (actually re-doing the wiring so it is correct and per code). The current power feed wire from the genset to the transfer switch is in PVC conduit but is NM 8 gauge. I know this should be THHN but here's my question - what gauge should the green ground wire be? I think 10 gauge is ok, but want the experts' advice. I checked my stock of NM and found some interesting info - I have some 10 gauge nm that has a 10 gauge ground wire and is so labeled. I also have some 8 gauge nm that has a 10 gauge ground wire. I even measured them with a micrometer to verify they are the same size. Both are 3 wire plus ground. Interesting!
Thanks!
Tom
Thanks!
Tom
