do these have a vent on them like other jacks do, to breathe? Appreciate any info. Thanks
They're a non-ventilated, sealed system. The reservoir (tank) being behind the piston, ported through the cap
You have a very early example as witnessed by the simple release knob, the jamb nut king pins on the rear casters and the lack of a cross bar handle near the release knob. Early examples will also have a cast iron "car" that carries the load saddle where the later examples are fabricated steel.
Elroy also notes the exposed plunger spring.
It appears to Elroy as a 1-1/2 ton (3,000 pound) model WS which feature a "slot" in the main body at the plunger. If it is a WS, the between frame measurement will be 6-3/4".
The smaller OS series jacks (1-1/4 ton) measure 5-1/4 between frames and have a "notched" block at the plunger
You have a nice vintage piece worthy of a rebuild. Hiball can fix you up with a soft seal kit as a most reasonable price.
