The hole in the wall is where the old tin work was removed. I have to get this repaired today as it is an entry point for sub-freezing air that comes in from my nicely vented crawl space. Ideally I could have fixed this before they mounted the new duct work but the original idea was to change out the system in one day so we would not be without heat.
good job recycling looks like you've given yourself a much easier to service configuration too.
has the lintel begun to sag? on one of the pictures, looked liked 3 large beams of wood sandwiched between two long 2x4's. if so, how were these 3 beams secured together to avoid eventual sagging? Also, is it typical to use only 1 horizontal layer bracing on the framing?
I can't believe that I just found this post. Read the whole thing - WOW, most excellent build!!!!!!!
Really great built James!!
I totally love it so much, it's the best one in my list now
It's all come together nicely, the garage, the atmosphere, the color, the surrounding, all of it !!
And you know what, it's totally resemble my soon to be garage. Mine is also about 23' x 20' (7x6 m). Except mine is all concrete and it's half way around the world from yours. Oh and without a Porche
All of my plans were gone post by post going through your thread, and in my head was like "this is it, this is it !!".
Yours and Jack's will be my ultimate dream garage when I finally do mine, and of course the green will absolutely be the color of choice
again, great build and awesome inspiration !!![]()
Hi PV2986,
Thats is a great looking structure!
I see that you have already solved two issues that I have yet to deal with: the concrete driveway that leads to the driveway on your property and the fence surrounding your lot. Those details indicate to me that you have thoroughly planed your project. I encourage you to start a build thread so we can follow your progress.
Do you have plans for any type of pergola to allow you to go from the garage to the house without getting wet in a rainstorm?
Thanks for your kind words!
Jim
That'd be two of us, I didn't read *every* post but did park here for about 3hrs..very nice build!![]()
This is a gorgeous garage. And for whatever reason your door gave me the inspiration for the wood trim in my garage (even though they are not the same color).
Thanks for that![]()
Awesome build. is the green you used a stock color or a custom mix? Could you share it with me, I would like to paint my shutters and fence that color.
Fantastic build!!
