Space between floor and drywall
Mobilejay
Houston
What are you guys doing with this space? I am wanting to put down VCT and want to go up on the side of the concrete but that leaves me with a gap between the concrete and the drywall.
djjsr
In the cornfields
If you expect that your floor will ever get wet from bad weather or an occasional hosedown, you should leave a substantial gap between the drywall and the floor to keep the bottom edge of the drywall from absorbing water. Cover the gap with waterproof baseboard.
NM
Agree with other posters - go to a flooring store and get flexible, rubber baseboard and glue it to the wall. It's shaped with a berm at the bottom, to deflect water that hits the wall. I just installed 44 feet, and with glue and the baseboard it came out to about a buck a foot. They will have different colors to choose from too. The flooring store will also have the glue, which will cost about 4 for a caulking tube, which covers about 18 linear feet of the baseboard material.
Oh, and here's a tip -- DON'T duct tape the baseboard to the wall after glueing to hold it tightly in place at the top -- the duct tape WILL remove the sheetrock paper. Um... I have a "friend" that did that recently, ha ha.
slickgt1
I used 5/8" by 5 1/4" PVC trim. Never gonna rot
Exactly. Go to hd, get the PVC white trim. 3/4 by 3.5, 12' lengths, slightly over $20, but it will never need any maintenance. Ever.
csp
Franktown, CO
Vinyl cove molding:
