DeWalt Impact ready bit set question
rgeudy
Rockwell N.C.
Ok i have to admit i feel a little dumb. I just picked up a set of the impact ready bit set at lowes. For some reason i cant figure out how to get the 1/4" bits out of the bit holder once i put them in. Is there a trick to this? Is mine defective? I could only get it out with a pair of pliers, and I am almost positive that is NOT the correct way. Thanks for any input:thumbup:
jim2664258
LOL been there, done that. I actually exchanged one of those I got awhile back with the same issue. The guys at Lowe's were all sure they could just pull it out including one big dude but none of them could. They used pliers. Pulled another one off the shelf and it was easier to remove them, but still difficult. I think the only thing that will really cure it is a lot of insertions/removals {insert joke here} over time. Either that or some slight filing of the bits, which is what I did. They don't all have the same resistance.
canuckian
East coast of Canaaada
Lol...you mean the one that pivots? Mines the same way. I think it's just got a really strong spring that holds the bit. I've had to use pliers on mine as well from time to time.
R
rgeudy
Rockwell N.C.
Thanks for the replies guys. I guess ill just fiddle around with it awhile, just wanted to make sure it wasnt defective.
Jawn
Stuck in traffic, GA
I had a problem with that bit holder... after I removed the bit, I noticed the ring that locks it in was slightly bent. So I got out a pick and tore it out, since all I wanted was a magnetic bit holder without a guide sleeve anyway.
fr0mastaj
same here... i had to bust out my small Cobras to get the damn bit off.
hope you picked up the $15 set i posted :)
jhelrey
MN
Are you talking the bits in the impact screw driver? Because if so, just give it a light tap on concrete ( the tip of the bit) and the collar will release and the bit will fall out.
slipjointed
No, he's talking about the magnetic/clip bitholder that goes into the impact driver and holds the bits, or converts a chuck drill to bitholder.
Stuey
28m above sea level
I always have to use pliers as well. Surely there must be an easier way!
My feeling is that it's this tight by design, though.
