Here's today's wing work. This is a test mule to see if the foam cores used by RC aircraft enthusiasts would work as a rear wing on my track car. A lot of what you're going to see is ugly, so be prepared.
Here's my old wing in use. It comes apart into two pieces to fit in the car, but over the course of five years the junction point got too stressed and was no longer perfectly straight.
Here's the five-years-used wing sitting next to the test core. I will use a different airfoil profile for the final wing. This is one they had ready on the shelf.
My quick way to cut the support pieces is to draw them on a piece of paper, cut them out with scissors, and then lay them flat on the final material -- and spray paint a silhouette to transfer the pattern.
There's an aluminum tube that I'm running the length of the wing, for strength. One of these two L-pieces will connect to it. The other will be sttached to the wing, and also to a sheet of aluminum that is also attached (with structural adhesive) to the foam.
I had to set threaded sleeves into the pieces at the end so I can attach end plates later.
Anything and everything gets used for clamping the material while the adhesive sets.
Did I mention it's a test mule? The cutting here is very crude. But you can see where that L-shaped piece went. It also gets a rivet to connect it physically to the tube. But the adhesive I'm using (3M Scotch-Weld DP-110) is stronger than the material it's connecting.
I still need to skin it -- maybe with thin aluminum, I'm doing some tests for that overnight. But here it is test-fitted on the supports. I hit the aluminum parts with spray paint. There are no end plates on in the picture, but you get the idea.
