I have read a bunch on regulators in past threads and have a few questions since the more I thought I know, the more I realize that I am more confused.
1-Regulator question: A 3/8" regulator flows ~120 cfm. Why would I need to get a 1/2" or 3/4" regulator? My compressor's ouput is 17+ cfm out of the factory 3/4" valve.
2-Air lines: Many would say that since my compressor has a 3/4" output valve, I should plumb the airline with 3/4" piping or at least 1/2" so as not to create a restriction. But even the 3/8" regulator puts out 6x more cfm than my compressor can. Why would I want to spend more money to plumb my line with larger diameter piping.
3-CFM and max pressure of regulators: Looking at Parker, Wilkerson, IR and other brands carried my MSC and Grainger, I have noticed the following: a 3/4" regulator with a max PSI >175 (my compressor max's out at this) will likely have an output of 125 psi to 150 psi. I found a Speedaire unit that is Max 200psi but it is around $100. A harbor freight $5 unit has a max PSI of 200. What the hell is going on? I guess I could just plumb the lines (after getting a better understanding from #2 above) and just get 3 of the HF units. I'd like to have a few output lines: 40, 90 and 120 psi. I just can't spend $100 per regulator though. What are some cost effective solutions?
Thanks in advance for the responses.
