koditten
I just purchased a 08 tundra 4 x 4. This is a wrecked vehicle that I plan to put back together. I usually do one wreck every 4 or 5 years and use them as my daily driver.
Anyways, the drivers side steering bag is the only srs deployed. Will need to get the bag and seat belt replaced and the ecu reflashed or replaced before I can get the thing inspected.
My question involves the four wheel drive switch. I notice on the dash that I have the air bag symbol lit as well as the traction control light. The dash is blinking the four high and four low light at about 1/2 second rate. The truck does not engage the four wheel drive when the switch is turned to four high or four low. Is there a tie in between the srs and the four wheel drive? And if there is, does replacing the srs parts and getting the srs ecu replaced, allow me to have four wheel drive?
I'm fully expecting to have to take this to a Toyota dealer and have the Tech Stream hooked up to have some of the computer problems dealt with. Just would like to have a bit of info before I go forward. Any info will be greatly appriciated.
Thanks
KO
Thanks
KO
