ajchien
Any harm in using JIS screwdrivers in regular Phillips screws?
The angles/geometry/profile, whatever you want to call it, from Vessel today is not very different from the average screwdriver you can buy today from any reputable brand, US, Taiwanese, or European.
I've read that but it does seem that my Vessels fit JIS screws better than my Wihas or my junky Craftsmans. Definitely if I have to loosen a stuck JIS screw the Vessels are all that I'll use. They did all come with stickers on them that said "Won't cam out!!" so I do think there must be some difference there -- Phillips are supposed to cam out.
snip
Q: Why VESSEL's screwdrivers are not labeled “JIS”?
As you might know, VESSEL is the oldest screwdriver manufacturer in Japan, and made a contribution to set a JIS standard.
We do follow JIS standard for cross point screwdrivers. Because the technology to manufacture screwdrivers in Japan had already become above a certain level, JIS recognition system for screwdrivers became extinct in 2008.
So there is no authorized JIS manufacturer now, and we therefore cannot print "JIS" mark on our screwdrivers.
vessel megadora 900 & 930. which one is better?
wow. and i thought i learned everything about screwdrivers.
this mean that I have to spend more money. thanks GJ!
thanks DaveWMS PERFORMANCE,
It depends what features you're looking for in a screwdriver. In addition, which applications you have in mind for that screwdriver.
The Megadora 900 has diamond like particles embedded in the tips to prevent cam-out (JAWSFIT). It also has knurling at the top of the shaft to speed installation and post-removal of a fastener.
The Megadora 930 also has diamond like particles embedded in the tips to prevent cam-out (JAWSFIT). It has a hex bolster below the handle for extra break out torque for removing a fastener. Lastly, the shaft goes through the handle to allow the user to strike the screwdriver with a hammer at the top strike plate.
If I had to purchase my Megadora screwdrivers again, I would purchase the Medgadora 930 instead of the 900 I own since I work on automotive repairs. However, in 2009 or 2010, the availability of Vessel in the U.S. was limited.
Dave
Although funnily enough, I find that the screwdriver on my Leatherman fits JIS screws REALLY well, better than any normal phillips screwdriver, and even my Koken P2.![]()
just like Pozidriv created by Phillips Screw Company itself which went nowhere in the US but became universal in European Furniture Hardware.
I just ordered a couple Vessel megadora 980's off amazon. I thought they were quite reasonably priced and act as impact drivers also.
