Metric Flare Nut Wrenches One MAC (Rare! "ratcheting" open-end) One Snap-On. The photos look dark, these wrenches are ordinary chrome with some scuffs; but not "black chrome" or anything unusual. $35/pair
SHIPPED in the USA.
SAE Flare Nut wrenches Snap-On $40/Pair
SHIPPED in the USA.
I'll have a 5/8--11/16 flare nut wrench for sale if I can buy a Snap-On RSXS22 11/16 flare nut/ratcheting open end wrench (haven't found one yet...)
Snap-On air impact wrench IM510B 1/2 drive $110
SHIPPED in the USA
Waiting on photos
Snap-On cylinder-shorting tach dwell
There's more; I need time to sort through stuff, make some decisions, and take/process photos.
Snap-On LOW TORQUE air ratchet 3/8 drive FAR70B $60
SHIPPED in the USA
I have owned it since about '86. It has not been used much since about '90 when I quit auto repair as a profession. Hobby use only since then. I oiled it and connected to air two days ago--works fine.
I used it primarily to remove and install spark plugs. This is a LOW TORQUE air ratchet, (note the size of the air motor!) so there was no danger of over-torquing the plugs. Start the plug threads by hand to prevent cross-threading, hit the trigger, wait for the ratchet to stall--move to the next plug. The long handle allowed me to break-free tight plugs, and then use the air to remove them. It worked better than the 1/4" drive "mini" air ratchets for breaking tight spark plugs free because of the longer handle.
Has a two-speed trigger, and with the trigger fully depressed, is a bit "faster" than a typical air ratchet. Air exhaust is rotatable 360 degrees. Ratchet makes a distinct sound; lower-pitched and fairly quiet compared to the typical air ratchet. Easier on the ears. Is excellent for any "delicate" work--small-to-medium stuff that has clean threads; or will be torque-wrenched to final tightness. Would be good for installing/removing transmission valve bodies; or perhaps engine assembly--speedy for running down nuts 'n' bolts, but not so powerful that it'd get you into trouble.
Snap-On MT2500 v.2.2 scan tool $310
SHIPPED in USA
GM1, GM2, Ford1A, Ford4, Chrysler1, Chrysler2, Jeep1, Multi1, OBDII, 12V power cord, Personality Keys K1, K3, K8, K9, K13.
Mac stubby 3/8 ratchet XR1 $35
SHIPPED in USA
Chrome worn a little. Doesn't show up well in photos, and isn't that noticeable in person--mostly on upper part of first photo.
Craftsman 4-wrench set in plastic pouch. TINY wrenches. $12 SHIPPED in the USA
I'll combine shipping where possible.
